Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Sign in using an external account
Register Forgot Password?
A "knocking noise"or clunkish noise in front suspension?
Thread Tools Search this Thread Display Modes
Old 07-07-12, 06:30 PM   #1
Phresh2010
Trader Score: (3)
Phresh2010's Avatar
Default A "knocking noise"or clunkish noise in front suspension?
Here is a story of how this all began. During the first month or so during this year, I had swapped out my Megan EZ coils back to stock. The stock suspension at which time was not assembled and I had to compress and put it all back together. After the reinstall of the stock suspension everything was fine as if the car was back to stock form.
Then about 3 weeks it I started getting this "knocking" or clunking noise coming from the front suspension of the passenger side. At first the noise only occurred when I left my alley way and garage as the road is pretty uneven so I didn't think too much of it. Then the noise gradually increased over the course of the week, it doesn't all the time but during down hill acceleration sometimes from 0 or certain corners at low speeds the noise would occur. My friend took a look at it and noticed the front right spring was not in its correct setting and the noise could have possibly came from a "shifting spring". So he helped take it apart and corrected it, Noise got better just a little bit but still occurs.
After about 2 1/2 weeks of this nonsense I was driving my sister to work one morning and hit a pothole on my passenger side front and immediately noticed a even worse noise (louder knocking) on flat surface roads and regular driving. I brought it to the dealership the same morning and the reported the top mount and shock assembly needed replaced. It was all replaced and I had the car back within 2 days. When I got the car back I didn't notice any more noise on the way home until certain streets. The noise sounds as if it were the same noise before I hit the pothole. The continuous noise from hitting the pothole has been corrected, now it just sounds like it did before the whole "pothole" incident.
At this point I have no idea what is going on, all my bushings and bolts appears to be tight, I also plan on getting coils again soon and if changing the whole suspension out would correct this I wont worry too much about it. but until then does anyone know what is wrong?
SORRY FOR THE LONG STORY, JUST DIDN'T WANT TO MISS ANY CRUCIAL POINTS. ALL RESPONSES AND SUGGESTIONS ARE APPRECIATED.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
:2010:AWD:Xentec:GFX:F-Sport Intake:Megan:
Phresh2010 is offline   Reply With Quote
Old 07-07-12, 09:44 PM   #2
Phresh2010
Trader Score: (3)
Phresh2010's Avatar
Any input?
__________________
Old 07-07-12, 09:51 PM   #3
Hoovey2411
Trader Score: (16)
Hoovey2411's Avatar
As strange as it sounds I once had a clunking noise which I thought was coming from the front but it was actually the F-Sport rear sway bar come loose. Needed to be tightened. Stranger things have happened.
__________________
http://www.clublexus.com/forums/signaturepics/sigpic95774_1.gif
|Version 3.5 |TLN #918|
GIANTS|NINERS|SHARKS|WARRIORS
Hoovey2411 is online now   Reply With Quote
Old 07-07-12, 09:56 PM   #4
Phresh2010
Trader Score: (3)
Phresh2010's Avatar
all suspension components on my car right now are stock, I would have thought since the car was at the dealership for 2 days they would have checked if any bolts were loose...guess I'll check it myself tomorrow
__________________
Similar Threads
Thread Thread Starter Forum Replies Last Post
2004 IS Sport Edition Lots of noise front right mitchman28 Suspension and Brakes 2 05-08-14 08:48 AM
1991 ls400 suspension nightmares! dulobast25 LS400 2 10-22-12 12:12 AM
Squeaking sound when turning left... new.era.13 IS - Second Generation 6 05-03-12 11:56 AM
Need help re: active power stabilizer suspension nwang97 Suspension 4 10-05-11 10:33 AM
Finally got around to installing the Megan's on my 90 LS. Few Questions jdog0411 LS400 5 09-13-11 10:30 PM
Tags
2008is350, banging, ct200, ct200h, engine, es300, front, knocking, lexus, noise, replace, shock, side, sound, suspension, till
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
