my rim is stargged .19 8.5front and 19 9.5 rear.im drop on h&r spring.is it safe to run 5mm spacer all around to make it flush without fender mod.i really dont know much about spacer.i included the picture if anyone know please help
Any thicker than 5mm and you start to rick your safety; either not enough turns of the lug nut on the stud or getting a studded spacer that is prone to crack/fail. Either go with a 5mm, or get IS300 extended ARP lug studs and run whatever spacer you want.
