DIY: 2011+ MY LED Headlight Installation ("How To")
Old 11-16-14, 12:46 PM
  #211
jtsimaras
jtsimaras's Avatar
I've owned numerous cars and have signed up for numerous car chat forums and read so many various DIY instructions and this is by far the best I've come across Great JOB!
Old 11-16-14, 02:42 PM
  #212
Ants350
Ants350's Avatar
Yea I used this same DIY helped pretty good!
Old 12-11-14, 09:41 PM
  #213
Initial G
Initial G's Avatar
Just recently used this DIY myself, made switching 2007 headlights for 2012 headlights really simple. The hardest part for me was replacing the relay flasher. It was a PITA to get to the relay flasher in such a confined space.
Mad props to the OP and many thanks.
Old 02-14-15, 10:06 AM
  #214
axis77
axis77's Avatar
http://is.sewellparts.com/accessorie...2007/2400.html
so I need these lights, the fully loaded package, and all i really need to do is dremel cut the headlight holder.
but sewell website states this:
Our exclusive, revised lamp kit includes everything required to retro-fit your 2006 to 2010 IS250, IS350 or IS-F with a seamless ready-to-go method for installation to the stylish look of the latest 2012MY LED Headlamps.
Did they revise this process since OP posted his how-to or Sewell just failed to mention the gotchas of this project?
Old 02-14-15, 11:37 AM
  #215
jtsimaras
jtsimaras's Avatar
I probably won't ever do it unless a set of headlights fell in my lap But still Great write up
Old 02-15-15, 07:43 AM
  #216
rohanstar
rohanstar's Avatar
Question for you man
I notice in your after pics your DRL isn't let not the led the highbeam dimmed DRL did you disable them if yes do u lose highnean when do so ?
Old 02-15-15, 01:42 PM
  #217
NorCalIS
NorCalIS's Avatar
No. High beam is completely functional when DRL's are turned off.
Old 04-06-15, 09:12 AM
  #218
mandyfig
mandyfig's Avatar
This is a very good DIY. Thank you.
I have to replace the driver's side assembly, where do I get a 1) used one or 2) Quality aftermarket replacement. I am prepared to just replace it since with the condensation that happened, it actually rusted inside the headlamp.
I have been to fleabay and mazon and have seen aftermarket assemblies. Are they any good? And usually what fails, ballast, bulb?
Thanks in advance.
Old 04-26-15, 04:16 PM
  #219
mandyfig
mandyfig's Avatar
Thanks for this thread, I bought a Denso Ballast, OEM and using this DIY, I successfully did the change over. I had to splice though and it worked.
I had condensation on the DR side headlamp and procastinated. It ruined the ballast, all rusted out. I sealed the headlamp and hopefully cured it.
I am 2 for 3 on headlamp failure, the RX and now the IS. I have enhanced warranty on the RX after I sealed it! I think they will issue the enhanced headlamp warranty to the IS as well. They should.
again thanks for this great DIY,
Old 04-27-15, 05:25 AM
  #220
LexoticJ
LexoticJ's Avatar
glad you got that all worked out
I recently installed 2012MY LEDs and will have updated pics soon
Old 05-19-15, 06:17 AM
  #221
devo2nr
devo2nr's Avatar
The link to purchase these headlights isnt working for me, is there another place I can get them?
Old 05-19-15, 11:15 AM
  #222
dyongg
dyongg's Avatar
you should be able to call sewell and order through the phone or you can e-mail them. they are also a vendor here on CL so you can PM them as well.
Old 05-27-15, 11:02 PM
  #223
skoo74
skoo74's Avatar
looks clean! i need to do this on my ride..
Old 05-27-15, 11:37 PM
  #224
cruzck
cruzck's Avatar
Is the Sewell website no longer available to those who haven't registered with them prior to their close date? I would love some OEM or replicas at a fair price.
Old 06-29-15, 06:07 AM
  #225
mandyfig
mandyfig's Avatar
Well the replacement ballast which was an original Denso one is not kaput. It worked for a while. The bad thing I did was I spliced it. Now it is not working. Not the bulbs, tested it many times.
I finally went to utube and saw a DIY which actually splits the housing so you can actually get into replacing the ballast the right way.
I may have to go down this route.
There goes another set of ballast.
What I should have done when I found water was getting inside the headlamp was to seal it immediately. I waited and lucked out. Moisture severely corroded the ballast.
One thing that is stumping me is how do you pull the main connector? Just unhook and pull away? Thanks for any advise.
Quick Reply: DIY: 2011+ MY LED Headlight Installation ("How To")
