more tire help!
Old 04-15-12, 05:01 PM
altrego350
altrego350's Avatar
Default more tire help!
Ok so I took the front wheels off a second ago to check the brakes and found this
I'm thinking alignment or ball joints. Hope its just the alignment.
Old 04-15-12, 05:04 PM
laobo979
laobo979's Avatar
Normal issues on these car. Try to get the spc ball joint it should help.
Old 04-15-12, 05:34 PM
altrego350
altrego350's Avatar
So this is normal wear?
Old 04-15-12, 05:41 PM
Quik208
Quik208's Avatar
No. You need a alignment.
Old 04-15-12, 05:44 PM
d2fresh
d2fresh's Avatar
Are you dropped? I'd get an alignment and see how much % off it is before I come to other conclusions. It's probably your cheapest option too..
Old 04-15-12, 05:48 PM
altrego350
altrego350's Avatar
I am stock with f sport package.
Old 04-15-12, 06:39 PM
Quik208
Quik208's Avatar
You probably just need a alignment then. I don't see you needing a camber kit at stock height.
Old 04-15-12, 06:49 PM
altrego350
altrego350's Avatar
Oh and the really bad side is the inside. Not the outside. The picture flipped on me.
Old 04-15-12, 07:28 PM
Fuzzie
Fuzzie's Avatar
if you are dropped on F sport, u shouldnt really have an issue with camber wear. you probably just need an alignment. usually only get tire wear like that if u are dropped pretty low
Old 04-15-12, 07:31 PM
altrego350
altrego350's Avatar
I'm not dropped at all. The car is stock.
Old 04-15-12, 09:32 PM
laobo979
laobo979's Avatar
Yes it a normal issue on the IS cause of the suspension design. Do the search and you find hundredth of thread on this topic. Yes even at stock height. Tire won't get you past 25k I've seen from member. The toe setting suck.
jadeboy
IS F (2008-2014)
04-29-15 01:00 PM
HAiS250
Suspension and Brakes
17
05-06-12 11:50 PM
g2bme
11-23-11 09:45 PM
RocketGuy3
Southwest
08-26-08 10:29 AM
JJRHO
09-13-03 12:44 PM
Quick Reply: more tire help!
