Help: still confused about tires/wheels :(
Old 04-12-12, 03:51 PM
Newb2012
Newb2012's Avatar
Question Help: still confused about tires/wheels :(
I'm getting some mixed info on which wheels/tires I can put on my IS. It's a 2012 IS 250, RWD. Came with 18" alloy wheels (front: 225/40R18, rear: 255/40R18).
Under the "Tires and Wheels" section of the owner's manual, there are 5 dimensions of tires listed (Type A to E). Does this mean that I can use any tires with those specs? I am shopping for winter/snow tires and am hoping to get 4 tires/wheels of the same size, allowing for regular rotation and longer treadlife. Anyone have experience driving their IS RWD using 205/55R16 89W tires all around? (Type A setup according to manual). This would seem like the best setup for winter tires...relatively narrow (less slippage), and higher profile (longer treadlife).
I have called 2 lexus service centers near me and both have said that it's not advisable for me to switch wheel/tire sizes as this would mess with the way that the breaks/break drums align? However, tirerack techs said it wouldn't be a problem. Am I really stuck with my current wheel/tire configuration? I'm not sure where to get a definitive answer on this.
Old 04-12-12, 04:34 PM
laobo979
laobo979's Avatar
I beleave 16s are canda cars only. US don't come with it. As for winter I run 225-45-18 all around on my is350. No problem.
Old 04-12-12, 04:56 PM
Sango
Sango's Avatar
Canada used to do 16's but don't do it anymore.
Lexus Japan however does have 16" option.
http://lexus.jp/models/is/specificat...quipment0.html
Old 04-12-12, 06:00 PM
diverchris
diverchris's Avatar
Just a different question. For summer tires on the RWD; has anyone run the larger tires on the rear as well as the front tires for more rotation options?
Thanks,
Chris
Old 04-12-12, 08:00 PM
Sango
Sango's Avatar
Seems like you're asking about going all around the same size which would mean making the rear tire the same size as the fronts.
Yes, one can do that however it would look a bit awkward in a way since the vehicle looks like a AWD.
There is a bit of implications changing from stagger to non-stagger because it would change the handling balance, assuming one is aware of the current balance. It would affect all of the balance, acceleration, decelerating and cornering.
SonyHome
03-22-14 11:18 PM
ghuns
09-25-13 08:19 AM
boaclub923
11-01-11 05:51 PM
F BOMB
IS F (2008-2014)
09-22-08 02:54 PM
pylee257
08-29-07 12:20 PM
Quick Reply: Help: still confused about tires/wheels :(
