rough idle *without* rpm's dropping? Huh???
Old 04-11-12, 11:37 PM
Fizzboy7
Fizzboy7's Avatar
Default rough idle *without* rpm's dropping? Huh???
<2008 IS250, a/t, 23k miles, all service done>
Today I was stopped at a left turn arrow when my car started shaking for about five seconds. This was different from the carbon build-up shake when the rpm's dip and pop back up only for a second's time. Once the shaking started, I looked at the tach and there was no movement from the normal idle at all. It lasted about five seconds, which was longer than the past times when the rpm's momentarily dropped and bounced up (I'm pretty sure I do have a prior carbon build-up issue). No warning lights appeared either. So was this another form of the carbon build-up infliction, or something new?
Old 04-11-12, 11:41 PM
KillaIS250
KillaIS250's Avatar
I had a similar thing happen to me, I was pulling out of a parking spot, came to a stop just a bit after and the car began shaking for a few seconds. No lights, No RPM movement... just shaking. I've been having the Carbon Build up shake with the RPM dipping and everything, so I just chalk it up to that...even though the RPM's didn't dip that time. Having the TSIB performed in a week so lets see if it happens again...
Old 04-11-12, 11:47 PM
Fizzboy7
Fizzboy7's Avatar
I'm leaning more toward that notion too. It's just frustrating not getting a code for the dealer to read. I've had near-stalling issues for about three years now and it's getting old.
Old 04-11-12, 11:58 PM
KillaIS250
KillaIS250's Avatar
Damn really your dealer is requiring a code to be registered for them to perform the TSIB?
Old 04-12-12, 12:01 AM
Fizzboy7
Fizzboy7's Avatar
I think they said they cleaned something out about two years ago. Since then, they just say they haven't been able to reproduce it. Mind you, it usually only happens once every few months, but lately it's been once a month.
Old 04-12-12, 10:14 AM
seouljahon
seouljahon's Avatar
Same thing happened o me And my old roommates car but the dealer can't duplicate
Old 04-12-12, 10:19 AM
juvi22003
juvi22003's Avatar
Brought my car back in to the dealer for the 2nd time in 2 months, havent heard back from them as yet, but kinda having the same issues. Said they couldnt find any problems last month when i brought it in.....
Old 04-12-12, 10:50 AM
heyarms
heyarms's Avatar
The other day this happened to me. I had reversed up a small hill, put it back in drive and it shook without RPM change, as soon as i drove off it was fine. Was odd tho!
Old 04-16-12, 08:54 AM
juvi22003
juvi22003's Avatar
Got a call from the dealer friday one of the cylinder is miss firing and they will be replacing the piston.
Old 04-16-12, 11:11 PM
Fizzboy7
Fizzboy7's Avatar
Was that due to a code they found?
Old 04-16-12, 11:19 PM
isbbq
isbbq's Avatar
same thing happened to me...took back to dealer...they changed all pistons for me under powertrain warranty
Old 04-17-12, 02:02 AM
KillaIS250
KillaIS250's Avatar
Mine's going in for the Carbon Build Up TSIB too this week, likely will have to get new pistsons. Glad there's still 30k left on the CPO warranty for me.
michael22
11-19-20 01:12 PM
Fizzboy7
08-23-14 08:49 AM
derbrylac
09-20-12 08:38 AM
meis250
09-19-12 09:11 PM
Quick Reply: rough idle *without* rpm's dropping? Huh???
