Stretching tires question.
Old 04-09-12, 02:36 PM
aggatek
aggatek's Avatar
Default Stretching tires question.
I tried searching but didnt come up with anything. Probably not using the correct key words.
I used to have an Infiniti FX35. I changed my wheels to a staggered set up and one time i changed the rear tires to a meatier tire.
Soon as i had them installed and coming out of the garage I get 3 lights. Traction Control, ABS, and VSC light.
I was wondering does this happen to the IS as well?
I see a lot of guys stretching tires and I do not know how to calculate the diameter of the wheel once the tire is stretched so I am wondering if anyone has experienced this in the IS. I do have a set of rims 19x9 F and 19x10 R +26. My tire sizes are 225 and 245/35 tire. After calculating the sizes using an online calculator none of the measurements match.
How do you guys figure this out when stretching tires?
This is my first set I have ever stretched.
Thank you
Old 04-09-12, 02:44 PM
ZeroSeVen
ZeroSeVen's Avatar
None of my lights came on when I changed wheels and tires. The only time my "check headlights" came on was when I lowered my car with coilovers.
Check out the "Will these wheels fit" or "aggressive wheel fitment" thread Lots of good info.
Old 04-09-12, 02:46 PM
llamaboiz
llamaboiz's Avatar
Cant tell you hows its been calculated due to it was done thru trial and error over decades of car guys modding their cars. BUT i can tell you that 225/35's will fit your front and 245/35's will fit your rear and it will be fine with your offsets.
Old 04-09-12, 03:01 PM
laobo979
laobo979's Avatar
On RWD doesn't matter on an AWD it matter alot on the tire size you choose that can cause your rear diff to break.
Old 04-09-12, 03:36 PM
aggatek
aggatek's Avatar
Thanks. I appreciate your responses. Anyone have a shot of a rear tire with 245/35 on a 19x10 rim lowered on tein springs? I've been only able to see people on coils and kind of regretting not getting those instead. I'm a little weary of the gap it might leave
Miintt
07-04-17 12:51 PM
getafewliv
05-27-14 05:03 PM
WillyD
Pacific
05-19-11 12:56 PM
Milan
04-27-11 01:05 AM
Oreo27g
03-30-10 07:53 AM
Quick Reply: Stretching tires question.
