245/35/19 275/35/19
Old 08-02-12, 12:40 PM
67camaro
67camaro's Avatar
Originally Posted by SCWB
If you want wide tires, the best combo that won't cause you much trouble is 235/35/19 and 275/"30"/19.
245 on the front is too wide
and 275/35 in the rear is too thick of the side wall. The overall rear circumference will be around 6-8% longer than that of factory spec.
In case you bought those tires already, you have to modify your fenders to work with those tires. Heat gun, roll, shave tabs whatever it may take.
Ok thanks appreciate the info. I already have the tires on order through discount tires but they said I can swap out a different size within 30 days for free so that's why I figured I would give the 35 series a try since iv seen some comments about it and will work without any mods. And yeah I calculated .5 inches bigger around. The decision will be to down size from 30 series or a 255/35 series. Could I put f sport springs on it and still run the 275/30 and 235/35 in the front?
Old 08-09-12, 10:46 AM
67camaro
67camaro's Avatar
Well I put the 275/35 tires on and they fit almost perfectly. Looks amazing. Very Possibly could rub with 5 people in the car going over a bump with **** in the trunk but hasn't rubbed yet. So for the people that said it won't even come close to fitting it does quite nicely. Is def pushing it and wouldn't hurt going with the 30 series but I like extra rubber.
L350XIS (09-29-22)
Old 01-26-14, 11:25 PM
ms2619
ms2619's Avatar
This guy's ^^ comment was the only useful piece of information lol since no1 could show or answer if 275 35 19 fits
L350XIS (08-29-22)
Old 08-06-20, 03:06 AM
vincentFF
vincentFF's Avatar
Originally Posted by FPLinek
It has lowering springs on it but i am in the process of replacing them with oem springs from the lexus dealership. I have the front springs stock now and am getting the rear springs tomorrow. as of now i have 245/35/19 on the front with 35mm offset IS F replica rims.
I used the heat gun trick and the fronts no longer rub. im mainly concerned about if the back will fit and if it would actually be better for me to have 235 and 255. I just wanted really wide tires
So if I roll my front fenders I can run a 245/35/19 with a 8.5 inch rim and 35 offset rim? With no rubbing?
Old 08-06-20, 11:55 AM
primavera
primavera's Avatar
I ran similar set up last year 245/40/18 which has the same circumference as 245/35/19. If you rub inside, just use heat gun on the plastic liner and you will be fine without the need to roll the fenders.
https://www.clublexus.com/forums/is-...are-setup.html
Old 08-24-20, 01:53 AM
vincentFF
vincentFF's Avatar
Default Fitting a 245/35/19 19x8x5 35offset
so i have a 225/35/19 with a 19x8.5 35offset wheel up front right now and I wanted to switch up to 245/35/19 on my fronts for a wider tire look but ive read its "too wide" i rolled my front fenders and cut some of the inner liner did u have many problems trying to fit this setup? thanks
Old 08-24-20, 08:45 AM
primavera
primavera's Avatar
245/35/19 on 19x8.5 +35 should work in theory. Now it all depends on the tires you plan on getting. Some tires have square shoulders while others more rounded which help to clear the fenders. Michelins tend to run a bit on a wider side compared to other tire makers. If you already rolled fenders and removed the tabs you should be ok. If you still slightly rub in some place just use a heat gun to reshape the plastic liners.
Old 08-24-20, 10:29 AM
vincentFF
vincentFF's Avatar
and a 275/35/19 on a 19x9.5 35 offset should fit the rears no problem if i shaved the little
tab?
Old 08-24-20, 11:26 AM
primavera
primavera's Avatar
tab?
I'm sure with the right offset and correct tire this can be done. I run 255/35/19 on rear with no rubbing, I can't comment on 275 fitment. If you're not crazy slammed and don't carry passengers or heavy subwoofer box in the trunk this might actually work.
Good luck man.
Old 08-24-20, 02:51 PM
vincentFF
vincentFF's Avatar
Yeah theres so many people saying different things on this thread lmfao so I don't know who to believe and I did do fender mods the other day to try to make this fit and it seems to be more clearance overall in the front and back
primavera (08-24-20)
Old 08-27-20, 10:10 AM
vincentFF
vincentFF's Avatar
Are these the tabs that are touching the wheel and can you circle them so i can confirm we talkikg about the same tab. Thanks
Old 08-27-20, 11:56 AM
primavera
primavera's Avatar
I can see you're slightly rubbing here:
I suggest you drive it for a day, try turning and going up the driveway, speed bumps few times, then take the flashlight and look for fresh tire marks on the inside. Use heat gun and reshape it as needed. My one tire still rubs very slightly once in a while. When I switch to winter tires this winter I'll look inside the fender for fresh tire marks.
Old 08-27-20, 01:22 PM
vincentFF
vincentFF's Avatar
thanks man appreciate it and i rolled my fenders and stuff so i think after i reshape im good
primavera (08-27-20)
Old 08-09-22, 01:37 AM
bagriff82
1st Gear
bagriff82's Avatar
Default Not true
Originally Posted by ChrISF
you car won't drive with 245/35/19 and 275/35/19. it's not physically possible.
QUOTEi have a2006 Lexus gs420 with 245/35/19s
Old 08-21-22, 07:47 PM
L350XIS
L350XIS's Avatar
So much conflicting information in this thread.
One says 275/35 will work on 19x9.5 (+35) in the rear lowered on springs. Others say no it won't work.
Got wheels coming up to the above spec and want to fit as much rubber in the rear as possible. Hell I'd throw in a 295/30 if the 350's wheel arch allowed it.
But then again we're not driving 350Z's.
Going to bite the bullet and go for 275/30 for the rear. Will have to cut, shave, trim whatever the hell I need to to fit that rubber in there.
kaizen8
07-19-14 08:33 AM
streetx
IS F (2008-2014)
03-10-12 05:43 AM
cleethree
02-28-11 07:14 AM
eliteskill
SC- 1st Gen (1992-2000)
29
03-24-10 02:44 PM
klthomas
Wheels, Tires & Brakes Forum
10-26-06 06:55 AM
Quick Reply: 245/35/19 275/35/19
