Quick Help! Oil Change!
Not sure why you are still showing alot of oil on the dipstick... perhaps it's the vacuum holding up the small bit of oil in the dipstick tube??? Did you try checking a couple of times?
If you have about 4+ gals of dirty oil in your catch pan then you should be pretty good.
I didn't check my oil level after draining the oil completely... I only check when adding new oil.
swheat
06-29-09 06:52 PM
