tpms sensors on aftermarket wheels
Old 03-08-12, 03:26 PM
Fuzzie
Fuzzie's Avatar
Default tpms sensors on aftermarket wheels
have you guys/girls taken your oem sensors and installed them to your aftermarket wheels?
will i have to reprogram the sensors?
Old 03-08-12, 03:46 PM
Kurtz
Kurtz's Avatar
Nope.
You only need programming if you're wanting to use a different (or second) set of sensors.
Old 03-08-12, 05:08 PM
projectdna
projectdna's Avatar
the answer to the first question depends on the brand, model, and construction of the wheels. most one-piece wheels are TPMS compatible, though the hole for the valve stem has to be big enough to allow the TPMS valve stem. if the wheels are multi-piece, you'll need TPMS adapter brackets.
worst case scenario, if they don't fit, either re-drill the valve stem hole, or run a pipe bomb set-up.
Kurtz answered the second question.
mattds
03-02-16 12:05 PM
NTH
GX - 1st Gen (2004-2009)
12
04-08-15 02:05 PM
IS350S2K
10-03-14 11:05 AM
Sosodef79
07-27-14 08:53 AM
wyee99
12-08-09 11:41 AM
Quick Reply: tpms sensors on aftermarket wheels
