Non Flyaudio Navigation system - center vents fitment.
Old 12-17-12, 04:27 PM
  #91
nosurprise
nosurprise's Avatar
Originally Posted by rockopico
again, which tongs dude?
I got a PM from him a few days ago that's the same as this post (at the bottom of the page): https://www.clublexus.com/forums/is-...cturer-43.html
Although he said clips and tongs, he actually trimmed the vent outlets. I trimmed about 15mm off, it fits on the nav, but there is a fairly big gap at the top (see attached picture). Trimming more might help a little bit, but I got out a tape measure, and the way this is fitting now after trimming them is that the vents no longer fit inside the air vents from the dash (i.e. air is probably leaking out of it).
I think the reason it fits after trimming is that the new vents no longer go inside the dash air outlets (if someone had their nav taken out can check, I was too lazy to take it out again). Although he mentioned the '09 vents are bigger, they're actually smaller than the '08. The reason for not fitting is that the 06-08 goes in at a slightly vertical angle while the '09 nav forces it a more horizontal angle. After poking around I think it might had been easier to fit the original '08 vents by trimming the clips off the top of the nav, though that would probably stick out because of the shape :/
Attached Thumbnails Non Flyaudio Navigation system - center vents fitment.-imag0237.jpg
Old 12-30-13, 11:51 AM
  #92
arpegius
arpegius's Avatar
Does anyone know where I can buy the 09 AC vents? I have checked sewell, but including shipping to Canada they come down to $250... Any suggestions from the guys who replaced theirs already?
Old 12-30-13, 12:01 PM
  #93
Sffd103
Fire Slayer
Sffd103's Avatar
Try a local junk yard.
Old 12-30-13, 12:47 PM
  #94
tenaciousF
tenaciousF's Avatar
Use a paint can key to pull the vent out (free at home depot or lowes, flat hook one end, bottle opener on the other). Hook it into the small top slots where you release the clips that you push down with a screwdriver and pull. Works perfect, never touch the soft dash. Then use it to open a beer and celebrate. It's like it was made for it.
Old 03-20-15, 07:39 PM
  #95
08wis250
08wis250's Avatar
just figured out i had an aftermarket nag this whole time does anyone know how to update the navigation system?
Hoovey689
05-18-12 01:26 PM
Hoovey689
05-01-12 11:27 AM
Hoovey689
05-11-11 10:50 AM
Quick Reply: Non Flyaudio Navigation system - center vents fitment.
