To Stagger Or Not To Stagger
Old 03-13-12, 08:19 AM
  #31
slavver01
slavver01's Avatar
Originally Posted by laobo979
I would stick with the first setup. The second setup your on the edge of going over the 1% mark. I run 30s on my 19 and the pothole here in the northeast doesn't affect it that much. From 40-35 in the rear not that much of a notice on the oem setup.
i must be reading the tire calc results in the wrong way or something. where exactly is the 1% number you are talking about? im assuming its the diameter difference.
Stock Tire - 225/40R18 Search Tires Tire 1 - 255/35R18
Revs per Mile: 829.3 (225/40)
Revs per Mile: 831.3 (255/35)
Actual Speed: 60 mph 100 km/h
Speedometer1: 60.1 mph 100. km/h
Speedometer Difference: - Speedometer Difference: 0.241% too fast
Diameter Difference: - Diameter Difference: 0.24%
Stock Tire - 225/45R18 Search Tires Tire 1 - 255/40R18 Search Tires
Revs per Mile: 800.9
Revs per Mile: 799.0
Speedometer1: 59.8 mph 99.7 km/h
Speedometer Difference: - Speedometer Difference: 0.237% too slow
so going by these results the number are almost exactly the same, but the 2nd setup actually is slightly closer to equal then the 1st setup. thanks for the help
Old 03-19-12, 07:03 PM
  #32
kuuqi
kuuqi's Avatar
Yes the 1% difference is the different in diameter. It's best to keep it under 1% if possible. Even with 20's, you can get it to .9% which papahoff ran without problems.
I personally just prefer to stay closer to 0.5% or less but there's no need to.
Old 03-19-12, 07:22 PM
  #33
laobo979
laobo979's Avatar
Remeber your stock size is 225-45-17 not 18. So if your not comparing it to your stock 17's you could end up wrong.
Stock Tire - 225/45R17 Search Tires Tire 1 - 255/40R18 Search Tires
Section Width: 8.85 in 225 mm
Section Width: 10.03 in 255 mm
Rim Diameter: 17 in 431.8 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 7 - 8.5 in
Rim Width Range: 8.5 - 10 in
Overall Diameter: 24.97 in 634.23 mm
Overall Diameter: 26.03 in 661.16 mm
Sidewall Height: 3.98 in 101.09 mm
Sidewall Height: 4.01 in 101.85 mm
Radius: 12.48 in 316.99 mm
Radius: 13.01 in 330.45 mm
Circumference: 78.44 in 1992.3 mm
Circumference: 81.77 in 2076.9 mm
Revs per Mile: 832.9
Speedometer1: 57.5 mph 95.9 km/h
Speedometer Difference: - Speedometer Difference: 4.242% too slow
Diameter Difference: - Diameter Difference: 4.08%
nomz09
RC - 1st Gen (2015-present)
08-14-17 06:29 PM
Kuz
09-06-14 11:35 PM
07LEXPL
05-22-12 08:23 PM
xxrap985xx
03-14-12 09:20 PM
altezzza
08-10-11 04:43 PM
Quick Reply: To Stagger Or Not To Stagger
