my aux input is not working. HELP!
Old 02-05-12, 08:28 PM
claybaybay
claybaybay's Avatar
Default my aux input is not working. HELP!
i have a 2006 is350 i usually play my music threw a aux cable but the other day it just stopped working i checked the cable and its not that. I push the cd/aux button and it is like the aux is not registering. has this happened to anyone or know how to fix this?
Thanks
Old 02-05-12, 08:38 PM
GilIS250
GilIS250's Avatar
Try plugging in whatever you have on your AUX port to some sort of power supply. my iPod wont work unless I play with while charging it.
Old 02-06-12, 06:48 PM
claybaybay
claybaybay's Avatar
i tried it and still isnt working unfortunately
Old 02-07-12, 04:42 AM
Bichon
Super Moderator
Bichon's Avatar
I know you said you checked the cable, but did you try another one? If your existing one fits loose in the jack, or isn't inserted correctly, it won't press the feeler that enables the "aux" mode to be selected from the radio.
Old 02-07-12, 05:52 AM
greg0126
greg0126's Avatar
This may not be the case but it's worth checking anyway, in the fuse box under the passenger side dash check fuse #6. It's 10 amps and the only thing the manual labels it as is "audio".
There are a few other fuses for audio but all of the other ones are sharing the circuit with things like air conditioning and the clock so I doubt it is any of those.
steedls400 (04-20-18)
Old 02-13-12, 02:17 PM
claybaybay
claybaybay's Avatar
Yeah I used a different cable and all my fuses are good im gonna have to take it into a shop cause it doesn't seem to be a simple fix, but thanks for all the advice
Old 12-19-12, 06:15 PM
pr1canfri
pr1canfri's Avatar
Default aux
Did you get your aux to work. My aux stopped working today.
Old 01-02-13, 02:14 PM
claybaybay
claybaybay's Avatar
yeah it turns out that the aux circuit board in the radio was fried i got it fixed but it was 375$ i believe
Old 10-11-16, 01:35 PM
Kixclusive
Kixclusive's Avatar
Did you ever figure a solution, was it a blown fuse or something?
Old 10-13-16, 03:52 PM
whitebeast
whitebeast's Avatar
Wow, you could find used unit for about $200 ONLY
Old 03-07-19, 03:29 PM
dbs125
dbs125's Avatar
Default DISC•AUX Button stopped working, But Mode still works!
So my aux button stopped working and thought it was maybe fuse and circuit related but fortunately my Mode button on steering wheel still works to switch to Aux. Thank God for redundancy!
ac2000GX
GX - 2nd Gen (2010-2023)
26
12-06-17 12:34 PM
stothjr
HS 250h Model (2010-2012)
11-09-15 07:07 AM
lenunn1923
08-21-08 06:33 PM
mofogasm
02-04-07 08:06 PM
Quick Reply: my aux input is not working. HELP!
