gas pump keeps shutting off
Old 01-31-12, 10:50 AM
eggwoll
eggwoll's Avatar
This has happened to me a few times too. I also concur that it is gas station/pump specific
Old 02-01-12, 12:44 AM
jayfivelim
jayfivelim's Avatar
4th gas station today and still had the problem...had to hold the pump half way-ish..
Old 03-28-15, 09:22 AM
sagan
sagan's Avatar
Default Same issue
Having the same issue on & off. Mainly use Costco in SoCal. Doesn't seem to matter what location. Did anyone ever bring it to the dealer?
Old 05-15-15, 08:43 PM
garyst1638
garyst1638's Avatar
Any more ideas on this issue? I have been experiencing this for a couple of months now. Some gas stations are better than others but happens at most
Old 05-15-15, 10:52 PM
hirsch2is
hirsch2is's Avatar
not sure if these cats have it but prius since about 2004 had a gas tank with a soft plastic bladder that collapses as the fuel gets pumped to the engine so as to have as little air for exhaust fumes to collect. over time they will sometimes get too rigid and won't allow the tank to fill well. i really doubt this is the case but i will poke around on TIS tomorrow when I'm at work to see if i can't find any info. vent valve could also cause this if its stuck closed. they are normally open any time the car is off. could be causing an air lock in the filler neck causing a fuel backup. that usually means replacing the entire evap canister assembly to the tune of a million dollars. if you don't get a check engine light soon though its gonna be a hard one to figure out
Old 05-16-15, 09:15 AM
navarachi
navarachi's Avatar
We just had this with our Toyota, its probably the charcoal canister. Part with install is approximately $650.
Old 05-16-15, 10:05 AM
smokyis350
smokyis350's Avatar
I have been having this issue. About 10x in the past year.
Old 05-16-15, 04:19 PM
mk3ownz
mk3ownz's Avatar
im having the same problem as well, i'm interested in what the dealership will say.
3isIexus
04-14-20 06:55 PM
way2lo
09-16-17 07:02 AM
Negrodamus
GX - 1st Gen (2004-2009)
01-17-14 12:36 PM
GS4_Fiend
07-12-09 08:33 AM
Toaster
SC- 1st Gen (1992-2000)
15
05-12-07 09:52 AM
Quick Reply: gas pump keeps shutting off
