For those with Next Mod ING + 1 lip kit
Old 01-25-12, 08:07 AM
2IS350DT
2IS350DT's Avatar
Default For those with Next Mod ING + 1 lip kit
I had a lexus dealership installed the rear lip for me a while back, now I am putting the car back to stock and I noticed the two corners of my rear bumper are cut. I am not sure if they would need to cut the bumper to fit this lip kit..
can you guys provide any inputs?
Here are some pictures.
The first picture is what my bumper looks like now.. as you can see it is missing two corners.
The second picture is what the lip looks like
The third picture is what the front of the bumper and lip looks like when they are put together..
Old 01-25-12, 08:09 AM
LamTheSham
LamTheSham's Avatar
I don't have the Nextmod INGs+1 kit, but I'm pretty sure that isn't necessary...:3
Old 01-25-12, 08:56 AM
MoarLow
MoarLow's Avatar
they had to cut the bumper because that rear lip was bad fitment, but cutting the bumper was a horrible idea.
Old 01-25-12, 09:01 AM
starknight
starknight's Avatar
That sucks....one reason that authentic ftw
IS2FIFTY
IS2FIFTY's Avatar
WOW ! I would cry if someone did that to my back bumper
Old 01-25-12, 09:07 AM
LamTheSham
LamTheSham's Avatar
Should've taken it to a reputable body shop...
Old 01-25-12, 09:14 AM
dorkacho
dorkacho's Avatar
Awww that's not good
Old 01-25-12, 09:22 AM
2IS350DT
2IS350DT's Avatar
well.. i went there because my car was in a wreck.. so i went to the Lexus collusion center, and put it on while I was there..
so should I even try to go to the dealership and reason with them?
Old 01-25-12, 09:38 AM
2IS350DT
2IS350DT's Avatar
also.. when you guys install the lips, how do you guys hold it onto the bumper? this guy keeps telling me he needs to drill holes and put screws. Can't he just use double sided tape?
Old 01-25-12, 09:39 AM
MoarLow
MoarLow's Avatar
they are going to tell you that since it was an aftermarket part, they had to custom fit it, and will take no liability for non oem parts. tell them that they're idiots and should have modified the rear lip. ask whoever the district/regional manager is for the dealership and tell them they did a hack job on your rear bumper when the job was suppose to modify the rear lip to fit the bumper.
Old 01-25-12, 10:57 AM
starknight
starknight's Avatar
all i used is 3m tape. holds fine. Mine is authentic, so there is no fitment issue
Old 01-25-12, 11:06 AM
509IS350
509IS350's Avatar
My NextMod Vertex Rep was a little off in fitment. So I took it to a body shop and had it done right. No screws, no double sided tape, looks awesome. Authentic Vertex/kits have pre-drilled holes. I learned the hard way on that one.
Old 01-25-12, 11:38 AM
nmpeter
nmpeter's Avatar
+1
Old 01-25-12, 01:10 PM
2IS350DT
2IS350DT's Avatar
Originally Posted by nmpeter
+1
a man to that.
Thanks.
Old 01-25-12, 01:47 PM
KillaIS250
KillaIS250's Avatar
Proper fitment during installation sometimes requires cutting. If you follow the instructions Lexus provides for the GFX rear lip, it also states that you have to cut the rear bumper. to fit the wider openings on the lips. A lot of people (myself included) just installed it anyways, but many people have cut it.
Quick Reply: For those with Next Mod ING + 1 lip kit
