06 is350 with dead audio
I have a 2006 is350 with Nav and Mark Levinson at 55k miles. My Nav, Bluetooth, and A/C are still working properly but my radio and CD changer do NOT have any sound output.
I can go into my radio preset stations but there is no sound. When I press SCAN to search for other stations it just scans forever without stopping like no radio stations exist. This happens with both FM and AM freq.
I don't have any CDs in the changer but when I tried to load a CD, the load button and eject button do NOT respond; the yellow/green lights don't light up anymore.
I have a VAIS iPod connector and the iPod is playing sound just fine so it's not my speakers, the volume control still works.
I've tried turning off the car and restarting, the radio came back a few times but now it's completely dead. I've disconnected the negative battery cable but that didn't solve the problem.
Please help! Thank you
So with using the ipod connector and ipod you can play and hear sound. So that narrows it down...its not the amp or the speakers. So is your NAV screen working as normal? All the nav, HVAC, audio, etc functions correctly on the touchscreen? If so, its not the usual touchscreen failure that we read so much about on here. Perhaps it is narrowed down to just the ML lower changer portion epic failure?
Yes just the lower portion that is not working properly. I'll try to remove the whole head unit and reinstall all connectors this weekend to see. It's so bad that ML would break down just after 5 years and 55k miles
had the same problem, i made a thread about it if you go back you can see i had same issue, took to dealership but i was out of warranty but i had extended warranty from easy care, they replace the radio, not the nav just the bottom part, go to the hidden information to see what says failed.
How do you go to the hidden information section?
this is if you have a navi, first hold the "info" button (I did it for about 5 secs) then switch your parking light switch from off-to parking lights-repeatedly while still holding the info button....it takes about 5-6 cycles...an poof the NAV screen enter yet another Service menu.
i had the audio fail as you see in the picture thats why i had no sound, but my aux was playing perfectly fine
