MPG dropping...after 4th tank, what is going on.
Old 12-20-11, 08:04 PM
lpv
lpv's Avatar
Default MPG dropping...after 4th tank, what is going on.
I get gas at the same Chevron and this was my 4th tank. My tank mpg estimate is at 17.5 mpg currently and it has consistently been at 22mpg for the last 3 tanks. My driving habits have been the same. The wife did take it for a spin on the first 30 miles of this tank though. She must have redlined it at every signal light. I am at about 70 miles now on this tank. Should I worry or have you guys gotten mpg this low before?
Old 12-20-11, 08:23 PM
JDKane527
JDKane527's Avatar
It happens, just wait until next time you fill up if it's still that low.
Old 12-20-11, 08:41 PM
ChrISF
ChrISF's Avatar
weird, i average 26mpg about 50/50 highway/city and i drive like an a**hole
Old 12-20-11, 09:01 PM
RDIS250AWD
RDIS250AWD's Avatar
mine has dropped and dropped since I've bought my car. But I've also added alot of weight since. 20" rims, lip kit, molded wald spoiler, sub box, and a alpine type x 12 with big a** magnet. Hopefully my gas mileage will improve just a little bit once I throw on my factory rims for the winter
Old 12-20-11, 09:30 PM
SiskoMax77
SiskoMax77's Avatar
Same here! I dunno what to say except observe her driving habits my friend....that might help a lot and also the tires (compound and thread wear) and tire pressure is quite helpful
Old 12-20-11, 09:55 PM
Sango
Sango's Avatar
Winter fuel blend?
Old 12-20-11, 11:29 PM
iRock
iRock's Avatar
probably her. All the women i know drive fast soooooooo yup thats normal.
Old 12-21-11, 12:31 AM
SiskoMax77
SiskoMax77's Avatar
Is the car an automatic transmission perchance? If so, my mom has an ML320 and does the most annoying thing (and gas consumption of all) run the ac no matter what and romp the throttle at everylight and late brake at everylight. i have noticed that does affect your mpg due to the fact the engine and transmission are playing a catch up game and thus the extra effort does put a damper on fuel economy. It is not a gradual build of power but a sudden surge......thus the dumping of the fuel and so on
Old 12-21-11, 04:48 AM
Bichon
Super Moderator
Bichon's Avatar
Maybe your wife did alot of short trips. Short trips (where the car doesn't get to warm up) are even worse for fuel economy than a lead foot.
Old 12-21-11, 06:51 AM
birador
birador's Avatar
here's a some explanations courtesy of fueleconomy.org
Quick acceleration and heavy braking can reduce fuel economy by up to 33 percent on the highway and 5 percent around town. New EPA tests account for faster acceleration rates, but vigorous driving can still lower MPG.
Excessive idling decreases MPG. The EPA city test includes idling, but more idling will lower MPG.
Driving at higher speeds increases aerodynamic drag (wind resistance), reducing fuel economy. The new EPA tests account for aerodynamic drag up to highway speeds of 80 mph, but some drivers exceed this speed.
Cold weather and frequent short trips can reduce fuel economy, since your engine doesn't operate efficiently until it is warmed up. In colder weather, it takes longer for your engine to warm, and on short trips, your vehicle operates a smaller percentage of time at the desired temperature. Note: Letting your car idle to warm-up doesn't help your fuel economy. It actually uses more fuel and creates more pollution.
Cargo or cargo racks on top of your vehicle (e.g., cargo boxes, canoes, etc.) increase aerodynamic drag and lower fuel economy. MPG tests do not account for this type of cargo.
Towing a trailer or carrying excessive weight decreases fuel economy. Vehicles are assumed to carry only three hundred pounds of passengers and cargo during testing.
Running electrical accessories (e.g., air conditioner) decreases fuel economy. Operating the air conditioner on "Max" can reduce MPG by roughly 5–25% compared to not using it.
Driving on hilly or mountainous terrain or on unpaved roads can reduce fuel economy. The EPA test assumes vehicles operate on flat ground.
Using 4-wheel drive reduces fuel economy. Four-wheel drive vehicles are tested in 2-wheel drive. Engaging all four wheels makes the engine work harder and increases transfer case and differential losses.
Old 12-21-11, 07:30 AM
HAiS250
HAiS250's Avatar
17.5 MPG is really low and you're constantly getting 22 MPG? I get about 27 MPG every tank i fill up 50/50 highway/city and i drive like chrIS250
Old 12-21-11, 01:51 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
winter blend : mpg went down...
Old 12-21-11, 02:01 PM
01ES300NYC
01ES300NYC's Avatar
dont feel bad i average 12 mpg with my 350
Old 12-21-11, 04:42 PM
reset2k
reset2k's Avatar
I was going to say... I also have a 350 and I was like wtf? 22+ mpg avg? What's wrong with my car!
I average about 17-19 mpg on my 350 (all city for the most part)
Old 12-21-11, 04:55 PM
JoshIS408
- - G T V I P - -
JoshIS408's Avatar
if it makes you feel any better my last avg was 15.6
Quick Reply: MPG dropping...after 4th tank, what is going on.
