water/ moisture in Headlight
Old 12-01-11, 02:13 PM
genaos11
genaos11's Avatar
Default water/ moisture in Headlight
i been realizing pass few days my passanger headlight been getting water moisture inside ( there no cracks or damage on the headlight) , im thinking more then likey headlight seal wearing out those anyone know how to take them apart , and what type seal i need require to use seal it back up? or it can be something else ? thanks
Old 12-01-11, 02:19 PM
kumquatism
kumquatism's Avatar
I wouldn't recommend opening up your headlights unless you know what you're doing. If you still want to continue, use Nissan rubber butyl to seal it up after you open them. Throw some silica packets in to soak up any remaining moisture.
Old 12-01-11, 02:22 PM
shiny250
shiny250's Avatar
Did you recently install HID bulbs, parking lights, etc? If so, check and see if you accidentally did not close the covers properly. If thats not the case, try drying it out with a hair dryer and seeing if it comes back. If you want to take the headlight apart, then it'll be a lot more time consuming. There's a thread on here that shows how to bake and open your headlights (search blacked out headlight housing). You can also use a heat gun to open the headlights. Use gasket sealant (comes in a tube) and apply where the old gasket was. Close up the headlights and you're set.
Old 12-01-11, 02:38 PM
shadowman
shadowman's Avatar
^^^ Agree... check to see if the cover is on tightly first. If someone changed the bulbs or installed HID kits, there is a chance that it hasn't been covered properly.
Throw in some silica or moisture absorbant packs and cover it tightly. You can buy them from home depot or Amazon.
If you seals on your headlights are worn, then I assume someone opened it up before... It's tricky to open the headlights. Heat gun will work, but it will take you a while. Quickest way is to bake it in an oven, but you have to be careful not to overcook it. There should be a DIY on opening up your headlights for blacking out the housing. Do a quick search...
If you car is still under warranty, have the dealer worry about it.
Old 12-01-11, 04:17 PM
Rash
hmm
Rash's Avatar
Do not open the headlights, my 2011 headlights is all blurry now.
Old 12-02-11, 06:28 AM
genaos11
genaos11's Avatar
about 5 months ago i put in HID light but recently only thing i did i put f sport in take but im going double check my work before i take anything apart.. thank you for information!
Old 12-02-11, 07:14 AM
RDIS250AWD
RDIS250AWD's Avatar
To open them preheat ur oven to 220 degrees place ur headlights in there with a cloth underneath for ten minutes then carefully pry them open with a flathead. You can use clear window caulking sealant to seal it back up. Bake again at the same settings and time and let ur headlights sit for bout half an hour before reinstalling
Old 12-02-11, 07:43 AM
tenspeed
tenspeed's Avatar
When I use a oven on lights, I preheat the oven to 250*F then turn it off. The light goes in on a piece of cardboard when the elements are off. No danger of melting plastic that way. Let it soak for 10 - 15 minutes.
Old 12-02-11, 09:20 AM
llamaboiz
llamaboiz's Avatar
Anytime you do bulb swaps, when you're finished and you're putting the bulb housing covers back on, you MUST use a flashlight to make sure you're putting the tabs in correctly, its very easy to get the tabs wrong because the cover will still 'snap' on. I've done countless bulb swaps on members cars and no one has ever come back to me complaining of condensation.
Old 12-02-11, 09:45 AM
Gville350
Gville350's Avatar
Throw some rice in it.
Old 12-02-11, 12:08 PM
genaos11
genaos11's Avatar
throw some rice? and how about after ?...
swat1727
10-08-18 04:39 PM
XSV
03-30-17 08:37 AM
itsivan
05-06-13 11:21 AM
cupid0210
04-12-11 11:09 AM
Quick Reply: water/ moisture in Headlight
