is the IS350 engine shared with any other vehicle in the Toyota lineup?
Old 11-10-11, 01:01 PM
embolism
embolism's Avatar
Default is the IS350 engine shared with any other vehicle in the Toyota lineup?
I detailed my buddy's Rav 4 for him and we were talking about it in general afterwards.
He told me we have the same engine and the hp difference is just b/c the IS350 is tuned differently. I believe he said his car had 268hp
This doesn't sound right to me. Can anyone confirm? thx
Old 11-10-11, 01:03 PM
Joeb427
Joeb427's Avatar
No direct injection in his 3.5L or I believe in any Toyota.
Old 11-10-11, 01:06 PM
TheDream
TheDream's Avatar
It's only shared with the GS350, but no "toyotas". The Camry, Highlander, Sienna, Avalon, ES350, RX350 all use the same basic port injected V6.
EDIT: from wikipedia:
2GR-FSE
2GR-FSE engine in the 2008 Crown
The 2GR-FSE engine used in the Lexus IS, and GS 350, incorporate Toyota's latest D4-S twin injection fuel system. This system combines direct injection with traditional port injection. Using direct injection and port injection simultaneously facilitates more precise mixing of air and fuel under low and medium load conditions for greater efficiency, while high load conditions dictate the use of direct injection alone for maximum power. The 2GR-FSE engine is rated at 309 PS (227 kW; 305 hp) at 6,400 RPM and 38.4 kg·m (377 N·m; 278 ft·lbf) at 4,800 RPM. The engine's service weight is 174 kg.
The 2GR-FSE was on the Ward's 10 Best Engines list for 2006, 2007, 2008 and 2009.[1][2][3][4]
Applications:
2006 Toyota Crown Athlete (GRS184)
2006 Lexus GS 350 (GRS191/196)
2006 Lexus GS 450h (GWS191)
2006 Lexus IS 350 & IS 350 C (GSE21)
2008 Toyota Crown Athlete (GRS204)
2008 Toyota Crown Hybrid (GWS204)
2009 Toyota Mark X (GRX133)
Supercharged
2009 Toyota Mark X Supercharged (265 KW, 355 hp)[5]
Old 11-10-11, 01:07 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
In North America:
The IS350 uses the 2GR-FSE, which is shared with the GS350.
The RX350, ES350, Highlander, Venza, Camry, RAV4, Avalon, Sienna, etc. use the 2GR-FE.
It's a similar block design, same bore and stroke, however the big difference is the head design and direct-port injection in the FSE engine. The piston design is very different as well.
So there are quite a few mechanical differences that make up that extra 38hp, but the basic engine proper while not quite the same, is very similar.
Jeff
Old 11-10-11, 01:16 PM
Hoovey689
Hoovey689's Avatar
I want a Toyota Mark X!!
Old 11-10-11, 05:38 PM
thISguy350
thISguy350's Avatar
i want the supercharger off the mark x...
1997Soarer
Performance & Maintenance
07-20-21 03:45 PM
IS3Fguy
08-11-14 05:37 AM
GFerg
11-17-05 10:21 AM
jrock65
09-10-05 05:51 AM
Quick Reply: is the IS350 engine shared with any other vehicle in the Toyota lineup?
