Caliper Paint?
Old 11-09-11, 03:46 PM
jmsharp02
jmsharp02's Avatar
Default Caliper Paint?
So I just saw on R1concepts website that they sell caliper paint: http://www.r1concepts.com/lexus-is25...liperpaint.htm
does this stuff actually work? And is it better than any other type of paint for break calipers if so? Just wondering.
jmsharp02 is offline
Old 11-09-11, 03:51 PM
langjaykev
langjaykev's Avatar
if you search around the forum,most people use dupli/g2
langjaykev is offline
Old 11-09-11, 04:06 PM
streetx
streetx's Avatar
g2 is very good
streetx is offline
Old 11-09-11, 05:47 PM
calvin2376
calvin2376's Avatar
https://www.clublexus.com/forums/sus...alipers-5.html
calvin2376 is offline
Old 11-09-11, 06:11 PM
516IS
516IS's Avatar
G2 FTW, one can is good for all 4 calipers...
516IS is offline
Old 11-09-11, 06:42 PM
509IS350
509IS350's Avatar
There's a thread on this. Idealy you want to take your calipers apart and get them powder coated with hi temp paint. For the diy'er, it all comes down to you and how confident you are on doing the actual work. Whether spraying or brush on, prepping is the most important step and a little patience. Taping off the stuff you don't want painted or getting contaminated with brake cleaner,ie plastic/rubber hoses. Making sure the paint cures before applying stickers and wheels. Goodluck.
509IS350 is offline
Old 11-09-11, 06:44 PM
jmsharp02
jmsharp02's Avatar
Thanks for the info all, at this point I have to wait until I get the right wheels anyway.
Old 11-09-11, 06:49 PM
Lexs350
Lexs350's Avatar
I ended up using the G2 but with a spray. Just need to clean calipers and mask it off. Also I ended up removing the calipers. But off course you Will have to bleed the brake system.
Good luck
Lexs350 is offline
Old 11-09-11, 07:03 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,127 Likes on 1,297 Posts
Searched for G2 Caliper paint and found dozens of threads in the 2IS forum alone! Here are a few you could find by searching
https://www.clublexus.com/forums/is-...+caliper+paint
https://www.clublexus.com/forums/sus...+caliper+paint
etc etc, try it!
DaveGS4 is offline
deejay
02-08-10 10:05 AM
sc30015
Suspension and Brakes
09-26-07 08:42 PM
dan206
Pacific
06-22-07 03:23 PM
tmf2004
Automotive Care & Detailing
10-30-06 05:04 PM
Quick Reply: Caliper Paint?
