Fog Lights not working
Old 10-04-11, 02:46 AM
Niche2425
Niche2425's Avatar
Question Fog Lights not working
My fog lights have not been working for a few months now. They worked just fine until HID kit installed x2 cause first one was bad quality (bad ballast) and after 1 12" JL audio sub with 250watt mono amp install. Ive checked all the low profile blade fuses in all the fuse boxes (engine compartment and inside the car compartments) Ive also took a peek at the other types of fuses that are not as easy to check and from the ones that I can see everything was fine. What else can I do/check before going to the dealership as I plan to install HID for the fogs, but obviously I gotta get the oem fogs to work again??? any input is appreciated and thank you
Old 10-04-11, 02:51 AM
GilIS250
GilIS250's Avatar
Hey man, do you have HIDs for fogs? try going back to stock.. if you are stock try switching out bubls...
I don't know, unless you cut the power to the cables, I don't see why they wouldn't work ...
Old 10-04-11, 06:32 AM
calvin2376
calvin2376's Avatar
I'm confused, you say they were working "until HID kit installed", which makes me think you installed HID fogs. But then you say you plan to install HID for the fogs, implying you still have OEM halogens.
Can you clarify?
If you installed an HID fog kit, then your problem is either the ballast or the bulb. Figuring that out involves just switching the ballasts then switching the bulbs to see which if either fixes it.
If you have OEM halogens and they're not working, then it's likely a larger electrical/fuse issue related to your audio and other installations.
Old 10-04-11, 11:22 AM
Gville350
Gville350's Avatar
Have you tried seeing if the ballasts are getting power? If so, check the wiring harness to the bulb for power.
GL!
Old 10-04-11, 05:38 PM
Niche2425
Niche2425's Avatar
I have the stock oem fogs in the car right now. I think I may have an electrical/fuse problem cause they don't turn on. Any suggestions on what else I can do to check em myself before resorting to the dealer?
Old 10-04-11, 05:54 PM
Gville350
Gville350's Avatar
So the fogs are and have only been halogen...never HID? Check the bulb yet?
Old 10-05-11, 12:34 AM
Niche2425
Niche2425's Avatar
Thumbs up
Never switched to HIDs. nope havent checked the bulb yet. good idea.
whats the easiest way to get to them?
Old 10-05-11, 06:30 AM
whitebeast
whitebeast's Avatar
did you turn off your high bean?
Old 10-06-11, 01:14 PM
LEXtegra
LEXtegra's Avatar
I'm still confused. LOL. But anyway. You said they worked just fine until you installed something somewhere. Either its the wiring for your sub somehow and or the HID kit ( I don't know if you mean you installed them in your headlights or what. But if the problem didn't start until you installed whatever it was, then I suggest to check the wiring from your install and make sure you didn't blow a fuse. Or possibly disconnected or cut a wire for the fogs.
Old 10-07-11, 07:45 PM
Niche2425
Niche2425's Avatar
DID not turn off high beam; however, I did switch high beams to LEDs therefore my high beams do not work as high beams. They only function as day time running lights now.
Old 10-07-11, 07:47 PM
Niche2425
Niche2425's Avatar
I installed a sub and some HID lights for my low beams. In addition I switched the highbeam aka the day time running lights to LEDs and by doing that u loose ur high beam ability and only the day time running lights function.
Old 07-12-13, 11:58 AM
beto
beto's Avatar
I'm having the same problem with 2002 gs300. My fog lights
Are stock n Haven't been working for a few months. I checked the fuses
N they were fine. Is there a relay for them???
Old 07-12-13, 12:40 PM
whitebeast
whitebeast's Avatar
i know you lose high beam function due to LED but it's gonna turn your fog off if you leave it at on position.
radiokilla
12-31-10 01:55 AM
charlayboy
07-18-08 09:29 AM
SC400_408
03-02-08 11:03 AM
T.K.O.
Lighting
03-24-07 12:32 PM
eddo1
02-16-07 07:03 PM
Quick Reply: Fog Lights not working
