anyone have experience with dead battery then check VSC and check system light on?
Old 06-13-15, 09:49 PM
sthakor92
sthakor92's Avatar
Thanks! I'll drive it around tomorrow and see if it pops back up. And then take it into auto zone and get the battery and possible codes checked
Old 06-15-15, 07:48 AM
Zatrekaz
Zatrekaz's Avatar
My check VSC light comes on at random also. I normally can turn the car off for awhile and it goes away... but it's quite annoying when it's there since I can't see my miles left, ect.
Old 06-18-15, 07:34 AM
usna2011
usna2011's Avatar
While removing my center console, which required the car to be in neutral with the ignition on, I killed the battery. I was listening to music and also took a break to eat dinner. When I came back I notice the overhead lights were dim. I tried turning the car on and the starter just clicked. After it did not start I got a VSC light. I disconnected both terminals and hooked it up to a trickle charger and continued working on the car. When I was done I connected the terminals back up and the car started back up, light disappeared and haven't seen it since. Its been about 2 months.
Old 09-03-15, 05:27 PM
Fittedlife
Fittedlife's Avatar
Default I have the same problem!
Originally Posted by DCQUEEN07
I ran into the same problem today. Car wouldn't start when I came out the gym. Before that I sat in the car charging my phone with the engine off and the lights flickered a bit. I figured it was the battery so I had it jump started with cables. Car started fine except now there is a check engine light. Vcs light the error exclamation light and traction light on. Anybody know what this could be?
Hello everyone I am new to the forum.
Last week, I tried to turn on my car and not even the dashboard would light up so I assumed it was the battery so my buddy helped me jump the vehicle. After it was jumped the VSC OFF AND P/s lights quickly came on aling with the check engine light. (Never has happened before) after driving for 2 miles, the car stalled and wouldn't turn on again. I have replaced the battery but I got no luck! Please help
Old 09-03-15, 07:00 PM
LexSense
LexSense's Avatar
I'd say it's possibly the alternator that has gone bad in this situation, which killed your battery too.
If you could get it to an Autozone, I think they should have a tester that could tell you if it's the alternator/battery and possibly pull the codes for you as well.
This would be my first guess though.
Old 09-04-15, 01:02 PM
Gville350
Gville350's Avatar
The battery starts the car, but the alternator runs the car during operation. Bet its your alternator.
Old 10-29-15, 10:20 PM
Inoma
Inoma's Avatar
Default P2238 Code
Good morning all,please I drive a camry 2007 Hybrid. Was driving this morning and the Check VSC came on and all other lights.
I scanned the vehicle and got the P2238 code. Please can anyone help?
Old 10-30-15, 04:02 AM
srt1
srt1's Avatar
How many miles? Do you have warranty til 80k mi? If so its covered.
Your specific code shows an A/F sensor.
1) dealer needs to reprogram(reflash) the ECM
2) you need to change out the sensor which is a diy, to save money
This is what's recommended by the dealership.
gsssss
01-23-23 09:57 AM
HarrierRX300
RX - 1st Gen (1999-2003)
18
04-10-16 04:16 PM
boss22
05-02-12 04:58 PM
jiimpman23
04-05-12 07:20 PM
Quick Reply: anyone have experience with dead battery then check VSC and check system light on?
