is350 vs g37s
Old 10-03-11, 10:26 AM
  #31
Hoovey689
Hoovey689's Avatar
Originally Posted by mjh09e
The G37 exhaust note would be the worst part of being behind one in a race. It would make me cry because it is so euphonious and the is350 sounds like poop in comparison.
Eck I hate the 3.7. It's so course sounding. The VQ35 is where it's at
Old 10-03-11, 10:37 AM
  #32
ISF4life
ISF4life's Avatar
I raced agaisnt g35 and the new g37s and i'm confirm and approved this message -----> IS350 won everytime from dig or from roll ....on the roll it helps when using paddles shifter to choose lower gear and higher gear quicker...
Old 10-03-11, 10:45 AM
  #33
DryEye
DryEye's Avatar
Whatever the outcome will, just be safe dude!
Old 10-03-11, 11:00 AM
  #34
llamaboiz
llamaboiz's Avatar
Tips:
from 0: TC off/gear in D/ECT normal, do a small brake stand so you're not idling at 800rpm, say 1500rpm, you dont wanna go higher or you'll lose traction and just do a burnout at the start.
from a 40roll: TC off/gear in S and bring it down to 3/ECT normal, once you (him) hits the 3rd honk hit the gas and move the gear selector back into D.
Old 10-03-11, 11:07 AM
  #35
syzygy
syzygy's Avatar
Originally Posted by llamaboiz
Tips:
No, you want to temporarily limit the car to 2nd gear, not 3rd gear, from 40 MPH. The OP would be destroyed if he used 3rd gear at 40 MPH.
Old 10-03-11, 11:08 AM
  #36
ISF4life
ISF4life's Avatar
1500rpm still spin tires=lose grip=time. Therefore; drivers have to play with it, tires and set up are different result . For me is around 800rpm is about perfect
Old 10-03-11, 11:19 AM
  #37
brociouz
Uber 1337 Moderator
brociouz's Avatar
Yup, practice makes perfect. In my case, I need to get up to about 2k RPM in order to spin the tires on launch.
Old 10-03-11, 11:23 AM
  #38
Gville350
Gville350's Avatar
2k is where I launch on BFG KDWs...but at a prepped drag strip. So you'll wanna play around on non-prepped surfaces and find out where your particular tire "bite/grab" at what rpm. Perhaps drop down the air pressure down to 30 psi in the tires as well.
Old 10-03-11, 11:34 AM
  #39
06isDriver
06isDriver's Avatar
I was launching at 2300 yesterday with nt555 drag radials. street tires will break free anywhere from 1600-1800, in my experience
Old 10-03-11, 12:23 PM
  #40
cupid0210
cupid0210's Avatar
okay guys, i pretty much got the tips for the race from a stop, just foggy on the whole 70% application of gas pedal, so i don't just floor it?? lol. Also for a 40 roll, with the same ect off and no vsc on, but do i drop it down to 2nd or 3rd?? just wanna make sure i get the perfect launch because due to his hp i don't want to lose any ground, he is pretty cocky when it comes to his ride. i will be taking out my sub and my spare tire to lose some weight, plus im due for an oil change anyways, so I'll be sure to do that before the race as well. i don't have stock rims, im rolling on konig lace which should be lighter than the oem ones. im feeling pretty confident now. :-D
Old 10-03-11, 02:07 PM
  #41
2slixx
2slixx's Avatar
Infiniti G35, G37 0 to 60 and Quarter Mile Times
2003 Infiniti G35 Coupe 0-60 mph 5.4 Quarter mile 14.0
2003 Infiniti G35 Sedan 0-60 mph 6.1 Quarter mile 14.5
2004 Infiniti G35 Sport Sedan 0-60 mph 6.1 Quarter mile 14.4
2007 Infiniti G35 Sport (Manual) 0-60 mph 5.0 Quarter mile 13.5
2008 Infiniti G37 Sport 0-60 mph 5.4 Quarter mile 13.9
2008 Infiniti G37xS 0-60 mph 5.3 Quarter mile 14.0
2008 Infiniti G37 Sport Coupe 0-60 mph 5.2 Quarter mile 13.7
2009 Infiniti G37 Sport Sedan 0-60 mph 5.4 Quarter mile 13.8
2009 Infiniti G37x 0-60 mph 5.1 Quarter Mile 13.5
2009 Infiniti G37 Convertible 0-60 mph 5.4 Quarter Mile 13.8
2010 Infiniti G37 Sport Coupe 0-60 mph 5.2 Quarter mile 13.7
2011 Infiniti IPL G Coupe 0-60 mph 5.0
2012 Infiniti G37 Limited Convertible 0-60 To Be Released
Lexus IS 0 to 60 mph Times & Quarter Mile Times
2001 Lexus IS 300 0-60 mph 7.5 Quarter mile 15.1
2002 Lexus IS 300 SportCross 0-60 mph 7.5 Quarter Mile 15.4
2006 Lexus IS 250 AWD 0-60 mph 7.3 Quarter mile 15.5
2006 Lexus IS 350 0-60 mph 5.0 Quarter mile 13.5
2007 Lexus IS 350 0-60 mph 4.8 Quarter mile 13.3
2007 Lexus IS 250 0-60 mph 7.4 Quarter Mile 15.6
2008 Lexus IS-F 0-60 mph 4.3 Quarter mile 12.6
2010 Lexus IS 250 C 0-60 mph 8.3
2010 Lexus IS 350 C 0-60 mph 5.7
2011 Lexus IS-F 0-60 mph 4.2
With that being said.. Looks pretty close and can go either way, considering BOTH CARS ARE STOCK...
Old 10-03-11, 03:17 PM
  #42
Kurtz
Kurtz's Avatar
I removed the pre-07 Gs as they're again a different generation of vehicle/powertrain, and the IPL as it adds about $10,000 to the car for essentially 15 more hp- if that's legal I'm throwing a supercharger on the 350 for half that and we can race
I then removed the IS300 which isn't remotely the same vehicle (different chasis/platform/powertrain entirely) and the 250 and IS-F which is again totally different powertrain as being discussed...
At which point the slowest 350 times are in line with the very fastest G times.... and nearly all of the G times are .2-.4 seconds slower than even the slowest 350 time.
Simply put, all else being equal (tires, road conditions, driver, weather, etc)- Stock for stock the IS350 is a quicker car than the G3x is to at least to the 1/4 mile.
The 350 only coming in auto helps too, as it's harder for a bad driver to screw things up.
It's interesting because when Nissan went 350Z->370Z they added some power and reduced weight and got a fantastic performance result.
When they did the same engine swap going G35->G37 they added weight and actually slowed the car down.
Old 10-03-11, 03:21 PM
  #43
anthrax144
anthrax144's Avatar
Ignore the 70%. Torque brake up to around 1500 rpm and then slam the accelerator at the start. Would definitely help if you lowered the pressure somewhat on your tires down to around 30 for some extra traction. On the 40 roll, limit it to 2nd gear at the start and then immediately go to 4th after mashing the gas. This will keep it in 2nd until 60 but shift through the gears as normal after that. Oh, and be sure to run on < 1/2 tank of gas, 1/4 tank would be best. That's more weight drop than most anything else you could do (~ 70lbs). Do all these and you should smoke the G37.
Old 10-03-11, 05:06 PM
  #44
ImportISF
ImportISF's Avatar
Like everyone said you'll get him from a stop but he'll mostly pull up top if you guys keep going. Also you didn't mention what year the G37 is or if its AT or MT. Since 09+ came with the 7AT instead of the 5AT
Old 10-03-11, 05:17 PM
  #45
AmirLexus
AmirLexus's Avatar
a video to put on youtube would be awesome. =)
