TPMS Hardware?
![](http://oewheels.net/sensor-lexus-107j.jpg)
Those are the TPMS I bought on ebay.
My car only has ONE TPMS installed in the OEM wheels now (don't know why PO removed three of them)
anyways, I stopped by Toyota assuming I needed to buy some hardware. The hardware they had was $12 per wheel and it looked like a metal sleeve and two washers (one metal and one rubber) - that look to be already on the sensor.
What do I need to buy to mount these in the rims when my new tires go on tomorrow?
TIA!
You need the fitting kits from Toyota/Lexus or aftermarket. The metal washer and nut mainly, as the rubber seal is already on the new sensors. That's the only duplicate though, you do not have the metal washer or the nut yet, both of which you will need to mount the sensors.
Jeff
Jeff
I ordered TMPS last week on ebay, just forgot about buying this part too. Thought I might as well save a few more bucks while I have to wait on the TMPS anyways.
WIll this work Jeff?
http://cgi.ebay.ca/TPMS-service-kit-...a#ht_977wt_813
Sorry I don't mean to hijack your thread but it's quite relevant and maybe you'd like to purchase it too?
sorry to join in but i have a question, i bought the same sensors on ebay and when my mechanic put them in, he reset the sensors but they came back on in about 2 days, i was wondering if anyone had the same problem or is it soemthing i have to bring to lexus to get done correctly.
Jeff
the lexus dealer charge me 60$ buck to program as second set of my aftermartket wheels.i did have all the code write down by tires shop.they act like it took a hrs but i think 5 mins max.yes i got TPMS frome bay and it work on 09 also.
Doesn't look like they come with the washers, which is what prevents the nuts from scratching the wheels when you tighten them down. I'd try to find some that come with the metal washers. Those only come with the rubber sealing washers that already come on the sensors.
Are these washers that special or I will I just be able to buy these washers locally? I don't even know what they look like.
Thanks Jeff!
You can see what it looks like here:
https://i.imgur.com/1l4x9.jpg
Might be able to find them locally, I don't know. They're aluminum so they tend to do no damage to the wheels.
Jeff
Jeff
Super Moderator
If the shop that is mounting the tires doesn't have the tool to program TPMS and you are having them mounted before the sensors are programmed, make sure you write down the code numbers from the sensors just in case the dealer needs them.
Okay, yesterday the shop said they can't seem to get the blinking light to stop, like the car couldn't read it.. however a friend of his said that he's done 3 IS350's and they all needed to be driven before the light went away.. Is this true or should the light just go away right away?
