help bbs lm reps size offset fitment?
Old 07-29-11, 11:31 PM
jz1219
jz1219's Avatar
Default help bbs lm reps size offset fitment?
hey im wondering do i need spacer for bbs lm reps
19x9.5 Rear +40
19x8.5 Front +35
will it fit without spacer? and if im riding on stock height or lower?
i will lower the car later. will these still fit?
anyone can answer this question will be great thank you!!
Old 07-30-11, 12:16 AM
rookieIS
rookieIS's Avatar
you posted it in the wrong section, there's a sticky for the wheel fitments questions
Old 07-30-11, 12:17 AM
rookieIS
rookieIS's Avatar
search is your best friend.
https://www.clublexus.com/forums/is-...tart-here.html
Old 07-30-11, 10:38 AM
inno
inno's Avatar
It may not clear the calipers on the 350. I had to run 3mm spacer to get it to just clear in the front. Also, on Megan EZ coils, I am rubbing on every dip on the fender liner up front.
Old 07-30-11, 11:03 AM
projectdna
projectdna's Avatar
19x9.5 Rear +40
19x8.5 Front +35
like a few others have already mentioned, there is a there is a will those wheels fit? thread where you could have posted this question. but since your post is after the fact...
those offsets are conservative enough where you won't need fender modifications to make them fit. but... (see below)
i would contact the manufacturer to find out if you need to run spacers or not, though i am pretty much sure that with your offset you will have to run spacers.
inno> heat your fender lining and "push" the lining out of the way. that, or you can just let the tire rub a hole in your fender lining.
Old 07-31-11, 02:37 PM
100degrees
100degrees's Avatar
You need a 3mm spacer in the front to clear is350 brakes. Otherwise you are good. Depending on your tire size, the fender liner might rub.
Yazan7
04-10-14 01:31 PM
Kevin85
Wheels, Tires & Brakes Forum
07-03-12 05:31 AM
monkeybutt
03-25-11 05:00 PM
Supraman18
03-05-11 05:11 PM
NCDUB
07-26-09 04:39 AM
Quick Reply: help bbs lm reps size offset fitment?
