Bluetooth hands free music wont connect
Old 07-21-11, 02:40 AM
Phresh2010
Phresh2010's Avatar
Default Bluetooth hands free music wont connect
Been using the hands free bluetooth for music and lately it just connect, it says no connection or w/e but when i make phone calls it works (also the volume on the phone calls are quieter than before
anyone have the same problem and a solution?
Old 07-21-11, 08:42 AM
Hoovey689
Hoovey689's Avatar
First trouble shoot is make sure the bluethooth is on on the device and car. Yo check on the car go to menu audio BT Audio settings and see if the auto blutooth connect is on or off. Next go back and try select audio player, iirc there should be a little BT symbol next to whatever your player is called. If not try selecting it and see if it will pair. If all else fails, delete the portable player out and re-pair it (BT audio settings, register, then from the phone/player do what you normally would to pair the phone - menu settings blutooth setup register pair). Hopefully one of these works for you
Old 08-11-11, 08:50 PM
allst4r
allst4r's Avatar
could i connect to bluetooth on a 07 is??
Old 08-11-11, 09:00 PM
iRock
iRock's Avatar
You can connect your phone if you have nav
Old 08-11-11, 09:03 PM
allst4r
allst4r's Avatar
i thought it only connect via bluetooth with gen6 and up. 2010 and up???i hAVE AN 07?
Old 08-11-11, 10:11 PM
Hoovey689
Hoovey689's Avatar
You can connect your phone if you have Bluetooth. Don't need Navi, just the "push to talk" switch
To play Audio, yes it must be 2010 and up with the updated HDD Navi
Old 08-11-11, 10:26 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
You don't need navigation, all 2010+ have bluetooth phone and audio, with or without nav.
Jeff
Old 08-13-11, 07:22 PM
Kurtz
Kurtz's Avatar
To clarify (in the US anyway)-
Only cars with nav have bluetooth at all for 06-09 models. None of these can do music over BT, just phone calls.
2010+ models all have BT (including audio) regardless of nav.
Old 08-13-11, 07:32 PM
Phresh2010
Phresh2010's Avatar
forgot about this thread, well it started working again, weird...
ElmStreet
03-16-19 11:39 AM
l33ks
07-25-16 10:26 AM
eugenez
NX - 1st Gen (2015-2021)
05-27-16 09:11 PM
LexusGuy91
07-28-15 03:45 AM
WillRockwe
IS F (2008-2014)
12
08-04-14 06:48 AM
Quick Reply: Bluetooth hands free music wont connect
