Cutting the mudguard
At my current height i am scraping the mud guards which is the rubber or plastic piece that sits behind the front wheels and in the front of the rear wheels, does anyone else scrap this part when lowered? i was thinking about taking it out or just cutting off the area that hangs so the annoying scraping will go away
any thoughts?
any thoughts?
No idea about the front but my rear ones ripped off driving through that blizzard that Chicago got early this year. I took off my friends when we were installing blue underglow and it was simply two push-in clips and one 10mm hex to remove, that's to remove the rear ones.
2IS OG
You can remove them by taking out 2 push-type clips and a bolt that hold them on. BTW, these aren't 'mudguards' - they're actually diffusers that sit right in front of the tires. According to the factory service manual, these help stability and grip at high speeds by pushing air out from in front of your tires.
Javier
Javier
If you have a 2010, it's very simple. There are 3 bolts that are under the car the hold it in place on each side. If you feel right in front of the mud flap, you'll be able to locate them. There 10mm socket if I'm not mistaken. Remove all three, and the flap should come right off. I took mine off a couple weeks ago while doing my fogs.
Super Moderator
Wish they had simply used two or three bolts to hold each one on. I've had those push pin clips (part #75867-30120) break twice now while driving on heavily flooded roads. The dealer gets $6.99+tax for each pin, so it is a $15 mistake. (Sewell is cheaper, but the mud flap (sorry, diffuser) kept bouncing into the tire and making noise, so I wanted to take care of it immediately.
Uber 1337 Moderator
If anyone lost their mudguards/diffusers, I'm giving my old pair away for free: https://www.clublexus.com/forums/is2...ud-guards.html
I think sanding them down would be your best bet to minimize scraping.
marcuse
02-04-09 11:53 AM
