is250 awd + VarrsToen
Old 06-21-11, 01:33 AM
is250fsprt
is250fsprt's Avatar
Default is250 awd + VarrsToen
Will VarrsToen ES 3.3.2 work with the 2is AWD? I want these wheels bad. Can someone please chime in if you know they work. And if now does anyone know what other wheel company make Volks CE28N replica that will work with the AWD is. Thanks
Old 06-21-11, 02:45 AM
rich250x
rich250x's Avatar
they should work as long as the diameter of the tire+wheel is the same on all four corners
Old 06-21-11, 02:57 AM
aCortIS101
aCortIS101's Avatar
They should no problem. Are you looking into running a staggered setup?? If so, check out this thread and it should help.
https://www.clublexus.com/forums/is-...er-thread.html
Old 06-21-11, 03:06 AM
is250fsprt
is250fsprt's Avatar
I plan to run Non-staggered. So I'll be fine running 19x.9.5 on all four corner plus matching tires as well on all four corner. They come in 2 offset 12 and 22. Which offset do I get? Thanks for the reply
Old 06-21-11, 03:13 AM
is250fsprt
is250fsprt's Avatar
I'm worried 19x9.5 will rub with stock spec tire size 225/35/19. Its lowered on F sport springs.
Old 06-21-11, 08:05 AM
projectdna
projectdna's Avatar
assuming you're going w/ 19 x 9.5 +22 and 225/35-19, you're going to need fender modifications.
unless you think your ride height w/ f-sport springs are conservative enough where the wheels/tires won't do a number on your fenders.
PureZ
02-19-17 09:49 AM
gcomme2
11-15-15 06:02 AM
awd_pwnz
09-06-11 06:40 PM
Joyride250
03-02-10 05:18 PM
Burst32
03-07-07 08:25 PM
Quick Reply: is250 awd + VarrsToen
