Need help! (removing antenna wire from navi)
Old 06-01-11, 07:25 PM
uttam24
uttam24's Avatar
Default Need help! (removing antenna wire from navi)
how do i remove this wire from the navi. I tried pulling it but it didnt come out. is there a another way to take this wire out. thanks in advance
Old 06-01-11, 07:27 PM
ohiois350
ohiois350's Avatar
just pull harder, it just the antenna cable, my pull off easy.
Old 06-01-11, 07:39 PM
uttam24
uttam24's Avatar
i tried pulling hard but didnt move so i dont want to break anything... i guess i will give it a another try
Old 06-01-11, 07:48 PM
ohiois350
ohiois350's Avatar
just pull harder, make sure you hold and pull from the close to the plug so you don't break the cable
Old 06-01-11, 08:03 PM
uttam24
uttam24's Avatar
thanks i just pulled it with plier and it came off...
Old 06-01-11, 08:08 PM
ohiois350
ohiois350's Avatar
do you mind if I ask, why you have to take the unit out?
Old 06-01-11, 08:39 PM
uttam24
uttam24's Avatar
i just got done with upgrading the stock alarm system so i just wanted to clean up all the wires i ran behind the navi...and i am also working on something else when i get done i will post pictures
here is diy if you are interested
https://www.clublexus.com/forums/is-...ory-alarm.html
Shiryo
07-21-13 04:40 PM
Lexscme
10-10-09 08:32 PM
shajbot
11-15-08 01:28 PM
1loudlex
12
04-28-03 07:43 PM
Rit&Booner
03-08-03 01:00 PM
Quick Reply: Need help! (removing antenna wire from navi)
