Old 12-15-14, 04:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
Buyer's Guide to Used Lexus 2nd Gen IS Models (merged buying advise threads)
Old 10-28-10, 10:38 PM
  #91
projectdna
projectdna's Avatar
the most obvious is that right below the CD/DVD slot is the "mark levinson" logo.
another way is to check for the sound processor/amplifier located in the trunk. lift up the panel to access the spare wheel/tire well. flanking both sides are plastic panels. the left lid is a deep tray, while the right is a very shallow tray.
remove the panel on the right, and this is what you should see.
hope this helps.
Old 10-29-10, 07:47 AM
  #92
AKAlius
AKAlius's Avatar
hope this helps.
Ahh... Thanks Project!
Also, is there anything to look out for when searching for the right IS350? ie. Bad recalls that have never been freally fixed?
I've been reading a lot about the different recalls, but nothing seemed that big of a deal, at least the ones that came up in my search.
I've also, read about the stuck gas pedal caused by the floor mats, is this something i should be concerned about?
Thanks!
Old 10-29-10, 08:21 AM
  #93
projectdna
projectdna's Avatar
Thanks!
there aren't any (what i would consider) real "bad" recalls, though you may want to see if the said is350 has a service history at your local authorized lexus dealer/service center.
as far as the stuck gas pedal caused by the floor mats is concerned, as long as you have the right floor mats (read: specifically made for the 2is) you won't have a problem. there is a plastic hook on the driver's side floor that allows you to hook the floor mat to the car to prevent the floor mat from "creeping up".
hope this helps. best of luck with your search.
Old 10-29-10, 10:49 AM
  #94
syzygy
syzygy's Avatar
I see in your signature that you have a "modified" BMW M5.
Let me ask you - what exactly are you looking for/expecting from the IS350? What are your future plans? Do you want to modify the IS350 for more power, or will you be happy with stock power? Do you expect a certain level of performance (0 to 60 in X, 1/4 mile in Y)?
Based on your response, I will tell you if the IS350 is a good fit for your or not.
Old 10-29-10, 11:11 AM
  #95
projectdna
projectdna's Avatar
while i believe that the OP may be able to shed more light on that matter, i don't see or understand the relevancy of determining whether the is350 is a good "fit" for the OP.
reason being, the OP seems to have his mind made up with purchasing an is350, relegating the "fit" factor to nothing more than a footnote in the car searching/buying process.
however, i'm curious to hear as well, as it's now within the context of discussion.
Old 11-21-10, 08:44 AM
  #96
jaxxx
jaxxx's Avatar
Default buying used is350 with 50K miles?
looking into buying a used 06 is350 with 50k miles, how reliable will this car be?? should i try to get something newer with less miles??? or will this car be good till 150k?
Old 11-21-10, 09:00 AM
  #97
ScKcBc
ScKcBc's Avatar
i wouldnt worry about it. I also wouldnt pay more then 22k. I think it will definitely last 150k minimum
Old 11-21-10, 09:28 AM
  #98
greg0723
greg0723's Avatar
get it you'll love it. i have 68k on my is350 still runs new.
Old 11-21-10, 09:51 AM
  #99
jadu
live.love.laugh.lexus
jadu's Avatar
50k aint nothing, but still inquire about the maintenance
Old 11-21-10, 10:25 AM
  #100
Evitzee
Evitzee's Avatar
As long as all the recalls (fuel rails, valve springs, etc) have been taken care of and maintenance has been done you'll have no problem.
Old 11-21-10, 10:34 AM
  #101
D-Boi
D-Boi's Avatar
^^ Would any lexus dealer have this in their database?
Old 11-21-10, 10:42 AM
  #102
01LEXPL
01LEXPL's Avatar
^^ If it was registered by the P.O then it would be in their database & IIRC on lexus.com -> VIN
Old 11-21-10, 11:40 AM
  #103
Sffd103
Fire Slayer
Sffd103's Avatar
Default used car
I bought my 06' IS 250 8 months ago with 59K. I only have 62K on it now but it runs great and I wouldn't worry about it so much!
Old 11-21-10, 12:20 PM
  #104
brociouz
Uber 1337 Moderator
brociouz's Avatar
+1 for double checking the maintenance and recall/TSIB work. If all that's in the clear, I see no reason why this car should go for another 100k miles.
Old 11-21-10, 03:08 PM
  #105
chi123
chi123's Avatar
I just got an '07 IS350 with 49,270 miles at the beginning of October. Yesterday, just past 50,000 miles but I didn't get an extended warranty because these cars are generally quite reliable. Mine didn't come with any maintenance records since the previous owner never went back to the dealer. You can find out the past service online or from a Lexus dealer. Just make sure to keep it running in good condition and do maintenance regularly and you shouldn't have any problems reaching another 100,000 more miles.
Quick Reply: Buyer's Guide to Used Lexus 2nd Gen IS Models (merged buying advise threads)
