Problem On 6AT ATF Changed at 40KM
Old 05-10-11, 12:43 AM
kenken1984
kenken1984's Avatar
Default Problem On 6AT ATF Changed at 40KM
So, my little IS(6AT) has almost 45KM and wish to have the Gear Box Oil Change, here is my question and thanks.
1.shoudl we use OEM Toyota ATF WS grade Oil, is it a must?
2.Can IS use a kind of exchage machine to change ATF?, or, we can just loose the srcew and let the used one go?
3.if yes, how many Liter of oil we need and how many for manully change?
thanks alot...
Old 05-10-11, 01:12 AM
mong
mong's Avatar
SEARCH before posting, please!
2IS's automatic tranny fluid do not need to be change. The fluid should last the life of your vehicle and is unchangeable, anyway.
Old 05-10-11, 01:14 AM
KillaIS250
KillaIS250's Avatar
Can't change the ATF enough to make it worthwhile, leave it as it is
Old 05-10-11, 05:19 AM
kuuqi
kuuqi's Avatar
Yep. And if you absolutely had to change it, you have to use a machine to pump it out if I remember correctly. But either way you don't have to change it, ever. Same goes for the differential fluids. They're all lifetime fluids. The only fluids you'll ever change is brake fluid and engine oil
Old 05-10-11, 08:22 AM
rhy
rhy's Avatar
At 45k km, it would be good to check the fluid level but you won't need a flush.
Old 05-10-11, 08:34 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Where's Kurtz when you need him!
Old 05-10-11, 09:32 AM
iRock
iRock's Avatar
Old 05-10-11, 10:21 AM
nickr9287
nickr9287's Avatar
I could be wrong as I am new to the lexus community, but on the 60K service you are required to change the rear diff fluid on a 06 IS350.
Old 05-11-11, 01:31 AM
mong
mong's Avatar
You are WRONG
Old 05-11-11, 01:33 AM
mong
mong's Avatar
Check the fluid level? there's no dip stick for the 2is to check.
Old 05-11-11, 01:13 PM
Kurtz
Kurtz's Avatar
It's not physically possible tO change a significant amount of fluid on an auto 2is
The diff fluid CAN be changed but the US maintenance schedule never calls to do so and without a mechanical LSD back there I've yet to see anyone offer a good reason to open the diff at all
Old 05-12-11, 05:26 PM
nickr9287
nickr9287's Avatar
My bad its only on the IS-F that you change the read diff oil
Old 05-13-11, 04:58 PM
Kurtz
Kurtz's Avatar
Yup... and the IS-F (all recent years anyway) actually gets a mechanical LSD, which the ISx50 sadly does not.
Old 05-13-11, 06:35 PM
nabbun
nabbun's Avatar
lol iRock. That's friggin hilarious lmao
I wonder why Lexus sealed the transmission.
morphh
12-10-12 06:31 PM
adamc
RX - 1st Gen (1999-2003)
08-01-11 06:01 PM
KingNasGS4
05-10-10 09:17 AM
GS4_Fiend
Performance
03-28-09 09:30 AM
MJB_LEX
09-11-07 01:19 PM
Quick Reply: Problem On 6AT ATF Changed at 40KM
