Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Sign in using an external account
Register Forgot Password?
Pics of my '06 IS250 with 2011MY headlights w/ LED Strip
Thread Tools Search this Thread Display Modes
Old 11-01-12, 02:28 PM   #556
ohiois350
Trader Score: (11)
Quote:
Originally Posted by ISFPOWER View Post
dammit, my rear cover for the high beam doesn't even fit the newer 2012. this is trustrating, now i have to leave my car like that until the part arrives.
this is my light rear cover
Click the image to open in full size.
this is the 2012 rear cover, not even the same shape.
dam, I though you buy the complete lights from sewell? but the covers is not cost that much, but you got everything working now right?
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
07 IS350 Obsidian/2012 F-Sport front end conversion&2010 Tail lights upgrade/GFX side&rear/s2k tips/5000K Phillip D4s&4300k Phillip H11 rebased bulbs with Denso ballasts fog/White doors sill/6000K V-LEDS interior&parking lights/6000K V-LEDs back up lights/LED turn signal mirrors/LS door lock&LED/ F-sport complete suspension set up/ 20" Vossen VSF 1/hard wire 9500IX for speeding
14" GX luxury white with ecru
ohiois350 is offline   Reply With Quote
Old 11-01-12, 04:27 PM   #557
ISFPOWER
Trader Score: (12)
ISFPOWER's Avatar
yeahi think i got everythinh else. covers were only 8 bucks each, wont be here until monday though
ISFPOWER is offline   Reply With Quote
Old 11-01-12, 09:16 PM   #558
ISFPOWER
Trader Score: (12)
ISFPOWER's Avatar
well the led lights didn't light up but everything else works the same. i might have to try JoeZs way. might be because the ISF is a bit diff than the is350
Old 11-01-12, 09:59 PM   #559
ohiois350
Trader Score: (11)
i looked under the lexus IS-F fuse box for IGN2 and it seems we use the 20a fuse. and this is what i bought,
it holds 2 10a fuses. and it says MINI. will this be ok ? i dont want to run into any problems.
please help, my car is currently torn apart. thanks guys.
sorry I didn't get to take a close look at this post, the fuse line you bought it correct, but I just wonder the ISF used 20A IGN2? are you sure looking at the right IGN 2 fuse?
__________________
Old 11-01-12, 11:34 PM   #560
ISFPOWER
Trader Score: (12)
ISFPOWER's Avatar
i looked on the back of the fuse box in the engine indeed it says IGN2 and it had a 20a fuse in there.
i wired it the way joez did as well just a minute ago and still it doesn't work. every other light works including DRL, the orange sidemarker corner light just not the LED portion. i feel like it's a ground issue. im running out of ideas though. anyone know how to troubleshoot this issue?
Old 11-02-12, 12:22 AM   #561
ISFPOWER
Trader Score: (12)
ISFPOWER's Avatar
Default Update!
Thanks for those who have helped me with this process with PMs, etc inluding Ohiois350z, JoeZ, etc. i finally got it to work. working outside at 3:21 Am with about 39 degrees outside
Old 11-02-12, 10:21 AM   #562
ISFPOWER
Trader Score: (12)
ISFPOWER's Avatar
ok, last night they were working, this morning, they aren't working. my battery has been weak , it was dead yesterday but it still made the hids and the led strip come on. this morning, the hids come on but not the led strips. ive checked all wiring again and even redid it but nothing.
does anyone know a certain fuse i should look at? all the ones i looked at seems fine but when i looked at the headlamp fuse, it's more of a big relay.
any ideas?
Old 11-02-12, 10:43 AM   #563
runyun
Trader Score: (11)
runyun's Avatar
I didn't want to read through all the pages..
did you buy those lights from Sewell? (since they prewire it)
Figure out how to get those wires out of the harness? (just need a small toothpick to release it)
I bought my headlights and had to repin to get the LED strips to work since they were not bought from Sewell
__________________
93 LS1 RX7
03 SD/GGP GS3 - SOLD
07 SGM IS250 X-package
02 DC Tacoma
runyun is offline   Reply With Quote
Old 11-02-12, 10:44 AM   #564
runyun
Trader Score: (11)
runyun's Avatar
Also, there are Three wires that control the LED.
1. Ground
2. 100% brightness
3. 50% brightness
I'm assuming you know the colors?
__________________
93 LS1 RX7
02 DC Tacoma
Old 11-02-12, 11:11 AM   #565
ISFPOWER
Trader Score: (12)
ISFPOWER's Avatar
it wasn't prewired. i bought fully stripped headlights
1. Ground
2. 100% brightness
3. 50% brightness
i believe so, green wire is 100 percent and black is ground.
my parking side lights arne't working so im trying to find that fuse now.
Old 11-02-12, 11:14 AM   #566
ohiois350
Trader Score: (11)
glad you got them to work, but black wire is not the ground, the white wire is the ground the black wire is 50% bright
__________________
Old 11-02-12, 11:19 AM   #567
runyun
Trader Score: (11)
runyun's Avatar
Quote:
What he said.
There are 3 wires (all next to each other in a row)
__________________
93 LS1 RX7
02 DC Tacoma
Old 11-02-12, 11:37 AM   #568
ISFPOWER
Trader Score: (12)
ISFPOWER's Avatar
it was just the parking l ight fuse. thanks God. loll
Old 12-01-12, 03:10 PM   #569
scorpionge
Trader Score: (14)
scorpionge's Avatar
ScorpionGeo
Quote:
Originally Posted by Joe Z View Post
Finally, adding some much needed "Light" to this thread....... !!!
Some things to know... If you buy a pre-made kit, you don't have to deal with any of this stuff...
The only thing you have to do is swap the Flasher Relay cube, which sits in the space above the Brake & Gas pedal under the dash.
If you have an IS with AFS, you will indeed get a flashing AFS indicator light.. If you have an IS with just the Halogen headlights, you will not have a flashing AFS indicator.
So far the only known way to stop the blinking AFS light, is to crack open the cluster and block the light that passes through that area with something Black.
Also, the bumper brackets that screw into the bottom of the headlights, will need slight modifications to be attached to the new MY2011 lights.. Basically dremeling some of it off that sits over the LED wire dome cap on the underside of the housings.
But still, only 2 screws will line up after that.
I tried the new step mentioned, of only swapping the GREEN wire location, that DID NOT work on my 2008 IS-F.
So I went with what "thinktwice" originally did..
I snipped the thinner solid red wire, then tapped it into the Black & White wire underneath it..
Then I changed the pin location of the Green Wire to the empty spot... Done.!!
I also tested the Solid Black wire and Solid Green wire to confirm the differences between the 50% & 100% brightness of the LED strip.
I went with 100% power.
Also, the new Flasher relay needed is indeed Lexus / Toyota Part # 81980-06020
That takes all of about 5 minutes to find unplug & replug the new unit.
I only got pics of the Flasher swap so far.. (I was in a rush)
I will try to update this post in the near future with how the wiring looks before and after the slight modification done to the primary male plug connector on the new headlight.
Thanks for all input in this thread..!!
Regards,
~ Joe Z
JOE!
You my friend are a GOD, easy as pie!!! =)
__________________
scorpionge is offline   Reply With Quote
Old 12-10-12, 08:00 AM   #570
Raysonwbl
Trader Score: (0)
http://minkara.carview.co.jp/en/imag...3d10644229ac1a
Read this on a japanese website. This guy posted a wiring diagram that he did when he install the 2012 LED headlights to his 2006 ride.
Any comments?
Raysonwbl is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
should I go from 100% to 50% bright on LEDS? ohiois350 IS - Second Generation 17 10-01-13 06:06 PM
installion 2012 is250 led headlight ! ewcg0100 IS - Second Generation 0 08-28-13 12:55 AM
2012 Headlights - LED strip as a blinker? runyun IS - Second Generation 18 12-04-12 08:54 AM
Pic of my spark plugs at 70,000 miles Thinktwice IS - Second Generation 20 05-01-11 07:35 AM
Auto Butler +10 Hp (No 56k :( ) IS_Mine IS - Second Generation 17 03-26-07 12:10 PM
Tags
06, 2011, 250, car, clublexus, hardwire, headligh, headlight, headlights, is250, led, lexus, lights, strip, upgrade
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
