Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Sign in using an external account
Register Forgot Password?
Pics of my '06 IS250 with 2011MY headlights w/ LED Strip
Thread Tools Search this Thread
Old 03-23-12, 09:22 AM   #451
Jeff Lange
Keeping it Real
Trader Score: (1)
Jeff Lange's Avatar
Quote:
Originally Posted by ISBU View Post
Can't you just disconnect the headlight swivel ecu? It looks like it's independent from the operation of the headlights.
Yes, that has been covered before, and yes it will get rid of the blinking light, but it will also disable your auto-leveling system.
Jeff
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
2011 GSE20 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged with TRD Stuff
1993 TCR10 Previa 5MT Race Van
1991 FJ80 Land Cruiser Station Wagon
Jeff Lange is offline   Reply With Quote
Old 03-24-12, 09:08 AM   #452
mplopez
Trader Score: (0)
mplopez's Avatar
Mark2369
Quote:
Originally Posted by Jeff Lange View Post
This was the final wiring for USA, but I'd suggest if you're not good with the wiring, that you get someone who is to do it for you:
Click the image to open in full size.
Jeff
thanks Jeff!
Anyone in Northern California (the Bay) know of anyone that can re-wire this?
mplopez is offline   Reply With Quote
Old 03-27-12, 12:31 AM   #453
mplopez
Trader Score: (0)
mplopez's Avatar
Mark2369
Quote:
Originally Posted by mplopez View Post
thanks Jeff!
Anyone out there???
__________________
'07 IS250 Breakwater Blue /2012 Lights/ IS F style Grille/ Spoiler/ Interior LED upgrade/ Lighted door sills (blue)/ OEM iPod interface/ LED Puddle Lamps/ Nav Hack Part 1...
Old 04-03-12, 12:15 AM   #454
ISFBHR
Trader Score: (0)
Quote:
Originally Posted by rookieIS View Post
Update!
A member here suggested me to splice the red wire and tap it with the black&white wire. I did that and the LED's finally worked
in conclusion, after relocating the solid green wire, you must tap the red with black&white wire in order for LED's to work!
Any pics of this mate?
ISFBHR is offline   Reply With Quote
Old 04-30-12, 02:28 AM   #455
stasis3131
Trader Score: (4)
Man I read thru this entire thread and I seem to get the idea of how to install then in the car. Some of you guys must be astronauts or something .... Those damn diagrams seem harder then when I had to learn Chinese lol. But i have one question for anyone one that has gotten this to work. I like using the auto feature on my lights and I just want the LEDs to turn on when the car starts up so should I stripe the red wire to the black and white wire then instead of relocating the green pin just run a wire off the green to the acc on the fuse box or the igition on the fuse box? I will be tackling this job Thursday so any confirmation will be appreciated . Thanks
stasis3131 is offline   Reply With Quote
Old 04-30-12, 04:53 AM   #456
pearl10is
Trader Score: (0)
Yes I just got a fuse tap and had to tap it into the ig2 and connect it to the lighter green wire on the headlight. I only had to do it to one for some odd reason.
pearl10is is offline   Reply With Quote
Old 04-30-12, 10:46 AM   #457
stasis3131
Trader Score: (4)
Quote:
Ok I will try this to see what happens. Did you still tap the red wire to the white and black
Old 04-30-12, 11:00 AM   #458
ohiois350
Trader Score: (11)
did you got your DRL disable from the dealer? if it is not, that why you can get the leds to turn on by only one wire tap? I tried this before I could only have one light led to turn on, not BOTH, and the big white and blue stripe wire close to IG2 fuse is that the wire for DRL power, so I got my DRL disable so there is no power on that wire?
__________________
07 IS350 Obsidian/2012 F-Sport front end conversion&2010 Tail lights upgrade/GFX side&rear/s2k tips/5000K Phillip D4s&4300k Phillip H11 rebased bulbs with Denso ballasts fog/White doors sill/6000K V-LEDS interior&parking lights/6000K V-LEDs back up lights/LED turn signal mirrors/LS door lock&LED/ F-sport complete suspension set up/ 20" Vossen VSF 1/hard wire 9500IX for speeding
14" GX luxury white with ecru
ohiois350 is offline   Reply With Quote
Old 04-30-12, 11:04 AM   #459
pearl10is
Trader Score: (0)
I see and no I didn't move any wires I have the stripped kit from Sewell.
Old 04-30-12, 11:13 AM   #460
ohiois350
Trader Score: (11)
yeah I bought the stripped one from sewell too, but like one of the member here claim that he only tap one wire to the big white and blue strip wire to one driver headlight and it trigger both headlights on without tap to IG2 fuse, but he didn't have DRL disable? I tried using his way to hook up my leds, but did work, because I got my DRL disable, so no power there, so I have to do different way to make both headlights to work I have to wire two headlights to IG2 fuse to have both leds on, not just one
__________________
Old 04-30-12, 11:15 AM   #461
pearl10is
Trader Score: (0)
I also found out that with my headlights on auto I can't turn off my car unless I turn the headlights to another setting.
Old 04-30-12, 11:20 AM   #462
ohiois350
Trader Score: (11)
you have the same problem with Quang here too, I just help him yesterday about that issues
__________________
Old 04-30-12, 11:25 AM   #463
pearl10is
Trader Score: (0)
Quote:
And what was the end result?
Old 04-30-12, 11:39 AM   #464
ohiois350
Trader Score: (11)
well all you have to rewire them, I don't if you want to cut the green wire, but it is the only way to run them without the problem? what I did was cut the green wire on both headlights and run them to the IG2 fuse, but you MUST CUT the wire
__________________
Old 04-30-12, 11:59 AM   #465
pearl10is
Trader Score: (0)
Got it I'll have to do that when I get home
Similar Threads
Thread Thread Starter Forum Replies Last Post
HID retro? RCsGX GX - First Generation 47 11-12-13 11:59 AM
white LED plate bulbs RCsGX GX - First Generation 9 10-24-13 11:22 AM
should I go from 100% to 50% bright on LEDS? ohiois350 IS - Second Generation 17 10-01-13 06:06 PM
installion 2012 is250 led headlight ! ewcg0100 IS - Second Generation 0 08-28-13 12:55 AM
Matching fog and Leds ohiois350 IS - Second Generation 0 04-20-12 07:43 AM
Tags
06, 2011, 250, car, clublexus, hardwire, headligh, headlight, headlights, is250, led, lexus, lights, strip, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
