Pics of my '06 IS250 with 2011MY headlights w/ LED Strip
#257
Hi guys,
Let me briefly describe my situation (i have a 2006 IS250 Halogen):
I tried installing my 2011 Headlights (not from Sewell) today. I read through this thread 3-4 times and i thought i knew what i was doing.
I relocated the solid green wire to the default third empty slot next to the white and black wire striped wire. Then i installed it and tried to turn the parking lights on but the LED's are not turning on, even on low beam too. Everything else did work perfectly (lows, highs, turn signal), besides the LED's
I double checked my connections and everything was fine. I've no idea what I've done wrong that the LED's are not turning on.
#258
I am really confused now i have no experience with electrical stuff whatsoever, and i dont want to f' up my car
#259
Update!
A member here suggested me to splice the red wire and tap it with the black&white wire. I did that and the LED's finally worked
in conclusion, after relocating the solid green wire, you must tap the red with black&white wire in order for LED's to work!
#261
nice im down for a mini meet! sent you a pm.
the headlights looks good but a lot of work cus i did not buy it from sewell had to buy all the parts like covers / ballast / bulbs / LED connectors / and relay flasher which costs me another $200. wanted sonic ms to install but they quoted me $300 just for labor and i couldnt afford that and almost felt like giving up on the lights but finally i decided to install it cus the LED's are too sexy for me to let go :P
#264
Received 1,058 Likes
I already concluded this issue in post #203 of this thread
Finally, adding some much needed "Light" to this very thread....... !!!
Some things to know... If you buy a pre-made kit, you don't have to deal with any of this stuff...
The only thing you have to do is swap the Flasher Relay cube, which sits in the space above the Brake & Gas pedal under the dash.
If you have an IS with AFS, you will indeed get a flashing AFS indicator light.. If you have an IS with just the Halogen headlights, you will not have a flashing AFS indicator.
So far the only known way to stop the blinking AFS light, is to crack open the cluster and block the light that passes through that area with something Black.
Also, the bumper brackets that screw into the bottom of the headlights, will need slight modifications to be attached to the new MY2011 lights.. Basically dremeling some of it off that sits over the LED wire dome cap on the underside of the housings.
But still, only 2 screws will line up after that.
I tried the new step mentioned, of only swapping the GREEN wire location, that DID NOT work on my 2008 IS-F.
So I went with what "thinktwice" originally did..
I snipped the thinner solid red wire, then tapped it into the Black & White wire underneath it..
Then I changed the pin location of the Green Wire to the empty spot... Done.!!
I also tested the Solid Black wire and Solid Green wire to confirm the differences between the 50% & 100% brightness of the LED strip.
I went with 100% power.
Also, the new Flasher relay needed is indeed Lexus / Toyota Part # 81980-06020
That takes all of about 5 minutes to find unplug & replug the new unit.
I only got pics of the Flasher swap so far.. (I was in a rush)
I will try to update this post in the near future with how the wiring looks before and after the slight modification done to the primary male plug connector on the new headlight.
Thanks for all input in this thread..!!
Regards,
~ Joe Z
Picture 1 = NEW Relay
Picture 2 = NEW Relay and Old Relay, side-by-side
Picture 3 = Old Relay & Location (mine was green & blue)
Picture 4 = New Relay & Location (brown & black)
Picture 5 = Pearl Yellow LFA #P014 & MY IS-F
Regards,
~ Joe Z
#270
Hi guys,
I tried installmy 2011 Headlights today. but met a lot of problem,
I relocated the wires, but the leds still not working.
I just wonder how can I connect this plug (turn signal and led)?
there are five wires need to be connect, but I just find 2 wires(turn signal) can be connected. how can I connect rest of 3?
please help!!
please help!!
