Swapping Tires + TPMS
Old 04-11-11, 07:27 AM
bichoo
bichoo's Avatar
Default Swapping Tires + TPMS
I need put my summer tires back on my IS and I dont want to take it back to the dealer to do the swap, its just way to expensive there. The tires are off rims so I need to find a place that won't scratch the rims but my question is if I take it to any non-dealer for the swap, how is the TPMS affected? does it need to be reset?
Old 04-11-11, 07:49 AM
JEFFOS69
JEFFOS69's Avatar
If you're using the same tmps you can just move them over.
Old 04-11-11, 08:06 AM
bichoo
bichoo's Avatar
Do i need to reset them after moving them over?
Old 04-11-11, 08:43 AM
NickTomsyc
NickTomsyc's Avatar
I swapped mine about 2/3 weeks ago - got new rims/tires and they were able to move two sensors (two were corroded and wouldn't break free).... they put them on but I saw told they could NOT calibrate them (could have just meant the two new ones) .... they said only Lexus/Toyota had the codes.
Local Toyota dealer did it for me for $40 + tax
Old 04-11-11, 08:55 AM
bichoo
bichoo's Avatar
hmm..interesting..but i the rims are same, does it still need to be done?
Old 04-11-11, 08:59 AM
SPNinjA
SPNinjA's Avatar
You should just buy a second set of tpms off oewheels and program them as a second set. It'll save you the hassle of getting it switched out. Oh and you will not need to reset. The old tpms is already programmed to your car.
Old 04-12-11, 12:05 PM
cdtran2
cdtran2's Avatar
+1,
easiest way to do it. Just get a 2nd set of wheels with a 2nd set of tpms sensors and have the dealer program the sensors to your 2nd set on the car. every time you switch tires, all you'll have to do is select the appropriate tpms sensors using the satellite buttons on your left and you're done.
Fjaw
07-15-12 09:08 PM
aljodoro
GX - 1st Gen (2003-2009)
06-20-12 06:01 PM
OBP
11-23-09 12:14 PM
iron_lungs
08-30-08 01:45 PM
mikeho
01-03-08 10:57 AM
Quick Reply: Swapping Tires + TPMS
