Has anyone had the P0051?
Old 04-02-11, 08:23 PM
Hayk
Hayk's Avatar
Default Has anyone had the P0051?
Just a few days ago, my check engine light came on with the message "Check VSC". So I scanned the codes [P0051 - Oxygen (A/F) Sensor Heater Control Circuit Low (Bank 2 Sensor 1)], cleared it and went for a drive. It came back on.
The car is under 30k miles
Btw, not too long ago, I got a message about a fuel line recall or something like that. Could that be related in any way?
Old 04-02-11, 08:26 PM
mvlbr
mvlbr's Avatar
Take it to the dealer since it's still under warranty.
Old 04-02-11, 08:28 PM
Hayk
Hayk's Avatar
Will do, just thought I'd ask if anyone had a similar experience.
Old 04-03-11, 01:02 PM
Hayk
Hayk's Avatar
Anyone else?
Old 04-03-11, 06:22 PM
isflyby21
isflyby21's Avatar
sounds like the heater in the oxygen sensor has gone bad.. pretty easy fix they will just swap in a new sensor. the heater comes on everytime you start the car. therefore it will come right back every time you clear the code
Old 04-04-11, 11:15 AM
Hayk
Hayk's Avatar
Would it cause my car to run rich, as much as a bad O2 sensor would?
Old 04-04-11, 04:39 PM
isflyby21
isflyby21's Avatar
no the heater part of the oxygen sensor is totally different from the part that measures the oxygen level in the exhaust. the heater part is like a light bulb filament sometimes it just burns out.
Old 04-04-11, 05:17 PM
SpookJr
SpookJr's Avatar
My 2007 is250 with 60K CEL with VSC also came on this past weekend. I took it to autozone for CEL scan and came back P0051 just like yours. My car is no longer under warranty so hopefully I can fix it myself but I have no idea where to start. Time to start searching online. If anyone has any tips it would greatly be appreciated.
Old 04-04-11, 06:20 PM
isflyby21
isflyby21's Avatar
best thing to do is clear the code and start the car when cold . if the light comes on with the same code you also need a oxygen sensor
Old 04-04-11, 07:05 PM
Hayk
Hayk's Avatar
What is its purpose, and what would the possible outcome be when it's not working?
Old 04-11-11, 06:04 PM
isflyby21
isflyby21's Avatar
its just used to heat up the oxygen sensor to operating temperature faster. it wont hurt anything if you dont fix it.
Old 03-05-12, 05:46 PM
GoalPoster
GoalPoster's Avatar
Does anyone have the OEM part number for the right forward oxygen sensor (Bank 1, sensor 1) on the IS250 (2008).
I'm either blind or whacko, but I can't find it and all I can find is the Denso part number. I want to do a proper cross reference before I hit autozone.
Thanks,
GP
Old 04-10-12, 04:43 PM
kingster
kingster's Avatar
Thanks,
GP
I was told that I have the same bad sensor as yours. have you fixed the problem? How much for sensor and mechanic?
Person who told me was not sure where exactly was this sensor located. Does anyone know?
Is this the one by the battery or on opposite side? It is not the rear ones, I was told.
Old 04-10-12, 05:05 PM
laobo979
laobo979's Avatar
Kingster sensor are $100 shipped if you look online. Don't have too buy them from the dealer. If your bank1 sensor 1 is driver side primary.
Old 04-10-12, 06:52 PM
kingster
kingster's Avatar
Thanks. I will look into it!!
alcez42
02-26-20 04:43 AM
Luscombe8A
05-03-18 06:48 PM
natman
Maintenance
12-26-13 03:50 PM
cbones1979
RX - 1st Gen (1999-2003)
10-13-11 06:32 AM
thang tran
01-23-09 11:01 AM
Quick Reply: Has anyone had the P0051?
