How do I mount my JL 500/1 amp? Help!
Amp wiring and settings question
I've got a 2006 IS 350. A few years ago I installed a JL Audio 500/1 amplifier and a JL Audio 10w7 Pro Wedge. I used a JL Audio speaker wire to rca adapter to connect the car subwoofer audio signal to the amplifier. When I turn my volume up past about 45 I lose all bass. It seems to me the factory radio has a bass restriction causing the signal to fade out completly. Have any of you expirenced a similar problem? What have you done in attempt to correct the issue?
What settings do you have your 500/1 set at?
All suggestions appreciated.
Thanks!
Thanks!
Here is the amp mounted on the side (next to my ugly W7) where it can be easily accessed for changing setting, i also liked this setup because i figured all the air that was moving in/out of the port would help cool the amp...
Here is the 2 farad cap mounted behind it...
Here is the remote cutoff switch and JL bass boost ****.... I would consider both of them a must have..
Choas
01-04-08 04:20 PM
2001ES300
09-25-07 05:29 PM
