Headlight problem need advice
Old 03-28-11, 06:53 PM
A_Grasso
A_Grasso's Avatar
Unhappy Headlight problem need advice
Hey guys, so today after washing my car, I noticed that my drivers side headlight looked very foggy and wouldn't turn on anymore. They were blacked out by Tommy @ music box. I also have the ijdmtoy drl's, which can only fit without the covers, which might have caused water to get into the housing and short out the ballast. Does anybody have any advice or suggestions how to fix this? Or will I have to buy a new headlight?
Thanks
Old 03-28-11, 07:16 PM
Fjaw
Fjaw's Avatar
you can try using a hair dryer to clean out the condensation but you'll have to replace the ballast.
it's probably not the smartest idea to drive without the covers, water will get into it way too easily.
Old 03-28-11, 07:17 PM
JoshIS408
- - G T V I P - -
JoshIS408's Avatar
Umm your upposed to drill holes through the caps and silicone last i heard. my bet is water got in since your not using the caps
Old 03-28-11, 07:22 PM
A_Grasso
A_Grasso's Avatar
Do you know where I can get another ballast?
@ Josh: yeah that's what I'm going to do once I get the problem fixed. I feel so stupid >.<
Thanks for the feedback guys!
Old 03-28-11, 07:33 PM
IS25Heaven
IS25Heaven's Avatar
anyone know how much a new ballast would cost?
Old 03-28-11, 07:35 PM
A_Grasso
A_Grasso's Avatar
Yeah, does anyone know?
Old 03-28-11, 07:45 PM
MashinA
MashinA's Avatar
if tommy @ music box did the install why didnt he take care of the covers for u....or did u do the install urself?
Old 03-28-11, 07:52 PM
A_Grasso
A_Grasso's Avatar
At that time (November 2010), I had drl's which didn't have a decoder so I could put on the covers. Got the ijdmtoy drl's a month ago and completely forgot about the ability to drill holes in the covers as Josh stated.
Old 03-28-11, 09:00 PM
Fjaw
Fjaw's Avatar
read this one, https://www.clublexus.com/forums/is-...d-ballast.html
Old 03-28-11, 09:51 PM
A_Grasso
A_Grasso's Avatar
^^ very helpful thanks!! So I'm guessing just try and get all the condensation out of the light, replace the ballast and them I'm good to go?
Old 03-28-11, 10:09 PM
Fjaw
Fjaw's Avatar
yea. OR you can get rid of the condensation and take out any signs that you tempered with the high beam, city light, low beam and bring your car in saying condensation got in the headlight and your ballast fried.
I was going to do that but I ended up fixing my low beam HID.
Old 03-28-11, 10:16 PM
A_Grasso
A_Grasso's Avatar
^^ only thing is that my headlights are blacked out and my service advisor is already aware of that. I think I'm just going to get a new ballast and see what happens after that
Old 03-28-11, 10:25 PM
Fjaw
Fjaw's Avatar
do you have stock HID or aftermarket?
Old 03-28-11, 10:39 PM
A_Grasso
A_Grasso's Avatar
I have stock hid with afs
Old 03-28-11, 10:49 PM
Fjaw
Fjaw's Avatar
i think you have to replace the ballast under the headlight then but I may be incorrect. Just make sure you get all the water out before you close it up again or you'll get condensation. It took me a couple attempts to get it all out.
Quick Reply: Headlight problem need advice
