AWD staggered please chime in....
Old 03-08-11, 05:30 PM
Stokeless
Stokeless's Avatar
Default AWD staggered please chime in....
awd and lowered on road magnet springs. car has been lowered for 1yr with no issues except for the infamous vibration/wobble. I just installed some used
19" linea dynas along with the hub rings and there is a very noticable vibration throughout the car at almost any given speed. Even at stop lights the vibration is more than usual. sometimes more and sometimes less. The aligment and wheel balance were just done over the weeked and still have the same issue.
is this a common problem with the AWD with after marker wheels or is anyone else experiencing the same issue. any solution.
tire specs are
235 35 19 front
265 30 19 rears
Old 03-08-11, 07:04 PM
dubsesd
dubsesd's Avatar
awd's tend to have slight vibrations after lowering. some less, some more. may depend on how much the front is lowered compared to the back as well.
if the car is vibrating in general with the new wheels it my be your hub rings. might be loose and the rim might not be on center by a fraction of a mm
Old 03-08-11, 07:33 PM
jnguyen87
jnguyen87's Avatar
what are you widths? you'll get vibrations if your front and rear overall diameters are off by more then an 1 inch? Might even be less i cant remember. you have to take into consideration when you stagger awd your wheel widths and how much your tire might stretch.
Old 03-08-11, 07:37 PM
Stokeless
Stokeless's Avatar
specs on wheels
19x8.5 f
19 x10 r
many people on this forum runs this setup. please chime in. the over dia is well within the 2%. The hub rings are used but they fit nicely onto the wheels. tires appears to be in good shape. abot 95% life remains.
Old 03-08-11, 09:55 PM
jnguyen87
jnguyen87's Avatar
i dont think this is common between awd staggered setups. Im awd and im running a stretched and aggressive wheel setup.
Old 03-09-11, 04:48 PM
Stokeless
Stokeless's Avatar
If u search the forum for awd staggered. This is a common setup.
Old 03-09-11, 04:59 PM
Sango
Sango's Avatar
The probably the vibrations are due to it being lowered because it could affect the drive line. From what I was told, the drive line is designed with a certain tolerence and has a certain amount freeplay - depending on how it was lowered, it can affect it. This is not applicable to RWD.
Old 03-09-11, 05:12 PM
laobo979
laobo979's Avatar
I did not have this issue when i had my AWD. Make sure the hub ring you used is the rite size for the rim to the stock hub.
Old 03-09-11, 05:53 PM
rizzy
rizzy's Avatar
I'm running the same widths with coils and I have the vibration you speak of. I've noticed its usually between 40-50mph and at a stop. I don't really mind it, I bought a steering wheel damper to reduce the vibration in the steering wheel.
Old 03-10-11, 12:00 AM
pchan0
pchan0's Avatar
Did the steering wheel damper reduce the vibration?
Old 03-10-11, 05:10 AM
rizzy
rizzy's Avatar
I can tell you today when i install it.
Old 03-10-11, 08:17 AM
2FNQUIK
2FNQUIK's Avatar
vibration seems to be an issue with lowering an awd not the staggered setup
Old 03-11-11, 04:27 PM
Stokeless
Stokeless's Avatar
Are there any solution besides bring the car back to stock height
The vibration got worse after the wheels were install. Hub rings are the right size
Old 03-11-11, 04:39 PM
PaPaHoFF
PaPaHoFF's Avatar
what year is the car? from what I can tell, 06's seem fine with little to no vibrations. 07+ seem to be effected by the vibrations.
Old 03-11-11, 07:14 PM
rizzy
rizzy's Avatar
Got an '07 here.
Quick Reply: AWD staggered please chime in....
