VLeds DRL's 6k installed...Part III (DIY included)
Old 02-26-11, 08:08 PM
SeanIS350
SeanIS350's Avatar
Default VLeds DRL's 6k installed...Part III (DIY included)
First things first, thanks to Jmags and suxeLSI003 for there previous posts on this topic located here:
https://www.clublexus.com/forums/is-...installed.html
https://www.clublexus.com/forums/is-...d-part-ii.html
I thought it would be a good idea to post a DIY on this because it took me a while to figure out how to make everything fit in the moisture cap , so I'm going to try to post some pics to help some people out
I bought the DRL kit without the parking light, because I wanted a better one than the one that came with the kit. So i got the one at the link below:
http://www.v-leds.com/Vehicle-Specif...71398-1-3.html
Steps;
1) Remove the engine covers
2) Unscrew the washer fluid hose to make room to get to the light
4) Remove the moisture cap, and disconnect the old bulb, then remove it
5) Connect the module to the new LED DRL, and then to the wire for the light
THIS IS THE HARD PART:
6) Before you install the new bulb into the housing unit, push the module and the connector into the opening underneath where you insert the bulb. You may have to use a little force to get it to go down into the crack (see pics below). Make sure to also push or tuck in as much of the wires as possible
7) Put the moisture cap back into place, and lock it in with the metal bar
That's it!!! You are now ready to enjoy your new LED DRLs!!!!
Attached Thumbnails VLeds DRL's 6k installed...Part III (DIY included)-dsc05252b.jpg   VLeds DRL's 6k installed...Part III (DIY included)-dsc05256.jpg   VLeds DRL's 6k installed...Part III (DIY included)-dsc05287.jpg   VLeds DRL's 6k installed...Part III (DIY included)-dsc05303b.jpg   VLeds DRL's 6k installed...Part III (DIY included)-dsc05308b.jpg
Old 02-26-11, 08:11 PM
SeanIS350
SeanIS350's Avatar
Here are some before and after pics! The pics in the day time are closer to the actual color of the lights.
Attached Thumbnails VLeds DRL's 6k installed...Part III (DIY included)-dsc05290b.jpg   VLeds DRL's 6k installed...Part III (DIY included)-dsc05319b.jpg   VLeds DRL's 6k installed...Part III (DIY included)-dsc05325b.jpg   VLeds DRL's 6k installed...Part III (DIY included)-dsc05454b.jpg   VLeds DRL's 6k installed...Part III (DIY included)-dsc05444b.jpg
Last edited by SeanIS350; 02-28-11 at 09:23 PM. Reason: Added some day time pics!!!
Old 02-26-11, 08:24 PM
rgarjr
rgarjr's Avatar
tight
Old 02-26-11, 08:38 PM
SILVRLININ
SILVRLININ's Avatar
Looks niice! well done...
Old 02-26-11, 09:00 PM
quang
quang's Avatar
Great job!! For those with AFS, the space is tighter
Old 02-26-11, 09:12 PM
SeanIS350
SeanIS350's Avatar
Thanks guys!!! I have AFS on my ride, so the space shown in the pics is with AFS, but it was really darn tight!!!
Old 02-26-11, 09:52 PM
Cali2is
Cali2is's Avatar
Nice DIY... Looks good.
Old 02-26-11, 10:49 PM
kentaro
kentaro's Avatar
nice write up
looks more blueish than my 68 led ones
Old 02-26-11, 11:04 PM
revel
revel's Avatar
those look great!
Old 02-27-11, 12:45 AM
ernestfyu
ernestfyu's Avatar
i always wondered what people meant by "just push the module into the housing!" LOL
thank you for this.
Old 02-27-11, 04:18 AM
SeanIS350
SeanIS350's Avatar
Originally Posted by kentaro
nice write up
It's actually just my crappy camera that make them look so blue. They are less blue and more white in real life...
Old 02-27-11, 05:25 AM
Jmags
Jmags's Avatar
Everytime I see a reflection of these in my car I fall in love with them a little more
Where'd you get the parking lights? Any pics of just those on? My ebay parking light leds are a little weak
Old 02-27-11, 05:34 AM
Snubbles
Snubbles's Avatar
wow looks like a snug fit. good job
Old 02-27-11, 08:15 AM
tnogi
tnogi's Avatar
Nice write up!!
toHn
Old 02-27-11, 09:37 AM
SeanIS350
SeanIS350's Avatar
Thanks guys for all the positive comments on the write up... took a little effort to put it together so hopefully someone will benefit from it!
Hey Jmags, they are the Vleds 13 leds parking lights recommended by brociouz in his parking light review:
https://www.clublexus.com/forums/is-...ive-guide.html
The battery in my camera is dead right now, but I will see what I can do about some pics later, but the thread above should have some.
Quick Reply: VLeds DRL's 6k installed...Part III (DIY included)
