Gas light on, only 25 mile range?? How long can you drive on empty?
Old 02-19-11, 01:02 AM
  #31
shui3000
shui3000's Avatar
Man, you guys are such worry-warts. I regularly go past 0, usually 25-50 miles past. I've gone 75 miles past 0 and didn't run out of gas multiple times.
Old 02-19-11, 11:37 AM
  #32
Dvo
Dvo's Avatar
Originally Posted by gocubs08
I had a loaner for 3 weeks and I did an experiment! You can go exactly 64 miles after 0 and then you run out of gas.. That was in a 2010 IS250... I Imagine an IS350 would be around 50 miles. I had 2 gallons in the trunk to pour in when it died. Funny, it let me re-start and drive another mile and then it died again. It was fun... poor loaners
lmao, good thinking!
Old 06-18-12, 06:04 PM
  #33
IonSpray35
IonSpray35's Avatar
I recently took a trip, and got a personal best per tank, 456 miles. When my range ticked to 0, I was at 432.7 miles. So I got 23 miles.
Old 06-18-12, 07:31 PM
  #34
kingster
kingster's Avatar
I have driven only 20 after hitting 0.
Hypothesis or fact
1. contaminants etc... may get in our filters and damage parts in our engines
Question
1. if we are using 91 octane, should we still be concern with this intruders/radicals?
My opinion
1. if true that stuff is settled at bottom of tank and can damage parts of car/engine when we use the last 2.5 gallons of gas remaining in our tanks.
2.With hundreds of gallons of gas going into our tanks shouldn't it be the same when car moves, shakes or bounces.
3. Go to the beach, water looks clean but because of waves (water movement) you'll have some/lots of sand particles on body.
I am not an expert.It's just an analogy and opinion here
Old 06-19-12, 02:01 AM
  #35
sr20mofo
sr20mofo's Avatar
ive done 60 miles give or take multiple times with no issues and i drive a 350.
i start worrying when the needle fully passes the gauge line then i start looking for the nearest gas station lol
Old 10-10-14, 11:00 PM
  #36
Gerb
Gerb's Avatar
Today at 32km gas light went on. I thought there was more beyond the gas range.
Old 10-10-14, 11:55 PM
  #37
jdmSW20
jdmSW20's Avatar
man you guys are far more bold than me lol. my car hit 0 earlier this week and was like "hoooooooooooooooo my god! im still 2-3 miles from the gas station" hahahahaa. but 20-50 miles?! yall are crazy lol
Old 10-11-14, 09:49 AM
  #38
idoke1
idoke1's Avatar
^^LOL! I had that feeling too. I did however drove over 20 miles on my is350 with "0" miles left displaying on my guage. I did wanted to see how much further I could go but I didn't want to risk my fuel injectors and fuel pump for that. You never know what junk is on the bottom of your gas tank....
Old 10-11-14, 11:26 AM
  #39
scott1256c
scott1256c's Avatar
isn't the pump going to be pulling gas from the bottom of the tank regardless? So aren't the only contaminants that are going to be in there coming from the pump? Or (perhaps) water condensing from water vapor that would sink to the bottom anyway? And if it is sinking to the bottom, it will get sucked into the gas line regardless of whether or not your tank is full, no?
Furthermore, water (vapor) is actually an octane booster. People who boost will inject it, mostly to cool the charge, but also to boost octane. Not that injecting a lot of water from the gas tank is going to make your car run better, but it hardly seem catastrophic either. May run rough for a second or two. And again, if the gas is being taken from the bottom, that is going to happen regardless.
As to cooling the fuel pump, do they get hot? It would seem to me the fuel flowing through it should cool it a lot more than some fuel around the casing.
Anyway, when my "go get some gas" light comes on, it also tells me I have around 30 mi. left. I usually don't fill up until that happens. Mostly because I'm lazy. I also did that with my last car, which I had for 12 years. It was a chev, which are not supposed to be reliable, but I had no problems with it. I did run out of gas a couple of times with it, but when I did nothing catastrophic happened.
Old 10-11-14, 12:48 PM
  #40
scott1256c
scott1256c's Avatar
found the following on another site
Starting in the Mk4 Supra they came up with a clever design where the fuel pump sat in it's own small reservoir... this avoids several common problems with fuel pumps-
1. The problem where with low fuel the pump isn't being properly cooled... since you'd now have to run it to pretty much bone dry to exhaust the fuel in there cooling the pump
2. The problem where the pump sucks air because the level is low, the tank is poorly designed, and when you floor it all the fuel sloshes to one end, away from the pump pickup.
The ISx50 uses this same design.
So perhaps the pump will overheat, if run dry. BUT by the same token, unless you run it bone dry no problem, and any contaminants that don't float on gas will be pulled in by the pump almost immediately, including water from condensation. IOW the only problem keeping a 1/4 tank of gas will solve is the problem of no gas station within range of 1/4 tank of gas
Old 10-12-14, 04:56 PM
  #41
355F1
355F1's Avatar
I had an E46 330ci ZHP and it started counting BACKWARDS once I passed "0 Miles Left" Seriously...it was on like "-6 Miles left" when I pulled into the gas station.
MarcS
GX - 1st Gen (2004-2009)
23
07-02-19 09:14 PM
FrozenSC
08-04-05 08:53 AM
j2tha0e
04-13-02 08:32 PM
Deceptik1
SC- 1st Gen (1992-2000)
16
02-21-02 10:51 PM
Purplexed
14
08-13-01 11:40 AM
Quick Reply: Gas light on, only 25 mile range?? How long can you drive on empty?
