Illuminated Door Sill Question. . . . . .
Old 02-16-11, 05:48 AM
Rufio808
Rufio808's Avatar
Default Illuminated Door Sill Question. . . . . .
How do you know if you can put the Illuminated "lexus" Door Sill on your IS250?
Mine is a 2010 IS250 with the sport package, thank you for your time, much mahalo's
Rufio808
Old 02-16-11, 06:27 AM
willi3ja
willi3ja's Avatar
Fairly sure with the sport package it's just plug and play, but you can just pop your plate off real quick and look for a connector to verify. If there isn't one, all you would have to do is tap into the wires to make your own connector
Old 02-16-11, 06:37 AM
Scalene
Scalene's Avatar
2010 is not a simple plug and play, you have to do some wiring stuff. only upto 2008 that is plug and play, there is a guide here, on how to do it, just do a search.
Old 02-16-11, 07:39 AM
iRock
iRock's Avatar
Up to 2009 is plug n play and there are some DIY on here that people used for the 06 models that were NOT Plug n play maybe its the same process for 2010? Jus pop em off and see if the connector is there.
Old 02-16-11, 10:24 PM
brociouz
Uber 1337 Moderator
brociouz's Avatar
'07-'09s were completely plug and play. Base model '06s were not plug and play, the other packages were.
If I'm not mistaken, the '10s still have the connector there, but the wiring work needs to be done.
Old 02-16-11, 10:36 PM
rza8gamma
rza8gamma's Avatar
Read this
https://www.clublexus.com/forums/is-...ff-plates.html
Old 02-17-11, 01:00 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
I confirmed on my 2011 6MT that I did not have the connector at all. As far as I knew all of the 2010's had the connector, but it just wasn't connected to anything somewhere down the line. I could be wrong.
Jeff
Old 02-17-11, 04:24 AM
Rufio808
Rufio808's Avatar
Originally Posted by rza8gamma
Much Mahalo's Man, I guess I was just searching in the wrong place
Old 02-17-11, 04:25 AM
Rufio808
Rufio808's Avatar
Jeff
im going to check mine now, I was just afraid to start tearing up my door sills
Old 02-17-11, 04:35 AM
Rufio808
Rufio808's Avatar
So I looked under my door sills and there are the connectors present, and they actually have wires coming from them, I will check for power tomorrow after work
Old 02-18-11, 04:33 AM
Rufio808
Rufio808's Avatar
Also I contacted Darryl at sewell, he says that I have to conect the ground wire cuz its not connected to complete the circuit o.O, Thank you everyone for your time!
RUFIO808
knbnguyen
05-30-12 02:59 PM
Kybball#1
02-25-10 10:24 PM
PhilipMSPT
07-24-08 12:28 PM
Scottina08
01-04-08 07:21 PM
WhatYaGot
05-08-07 03:32 AM
Quick Reply: Illuminated Door Sill Question. . . . . .
