Cabin filter change
Old 02-07-11, 09:38 PM
SC3coupe
SC3coupe's Avatar
Default Cabin filter change
Hi, is there a DIY pictorial somewhere showing how to change the cabin filter in the glove box?
Old 02-07-11, 09:46 PM
chi123
chi123's Avatar
http://208.104.16.45/IS350/DIY_IS350CabinFilter.pdf
Before starting it, make sure your car is in "Recirculate" Mode for the heat/AC.
Old 02-07-11, 10:33 PM
305iskid
305iskid's Avatar
Its really easy, i did it today..seemed to make a big difference. Mine was nasty.. Open your glove box, pop out the shelf (its hard to pull the side out), when you pop that out you will see a cover plate. Take that off and there your go, just reach in and pull it out.
Old 02-07-11, 10:40 PM
CleverName
CleverName's Avatar
Interesting, just curious as to why... I did mine this weekend without giving it any thought.
V
BTW OP, the filter lifts up out of the plastic tray it is setting in before pulling it out...
Old 02-07-11, 10:42 PM
brociouz
brociouz's Avatar
It's extremely easy Jeremy, but if you need help just shoot me a text.
Old 02-07-11, 10:45 PM
Cali2is
Cali2is's Avatar
It would get very expensive if you did not have it in recirculate mode... Breakage would happen!!
Old 02-07-11, 11:02 PM
CleverName
CleverName's Avatar
Unless mine was already broken I have to seriously doubt that. It was a breeze to change and just lifted it out.
V
Old 02-07-11, 11:12 PM
Cali2is
Cali2is's Avatar
Well I'm just going by the owners manual. It states that the cabin filter cannot be removed unless it's in recirculate mode. I read at least one post of an owner with a major repair bill for not following this direction.
I would not want to be the unlucky one to test this one out!
Old 02-07-11, 11:13 PM
CleverName
CleverName's Avatar
Erk....
Just looked at the DIY, mine may have already been broken cause the tray stayed in and the filter paper simply lifted up and out! Grrrrrrrr
Now i gotta go investigate!
V
Old 02-07-11, 11:16 PM
foam
foam's Avatar
How often should you change the cabin filter?
Old 02-07-11, 11:18 PM
llamaboiz
llamaboiz's Avatar
i've never understood why people would want to have it on outside air in the first place?
Old 02-07-11, 11:20 PM
Cali2is
Cali2is's Avatar
Here's another reference. Post #3...
https://www.clublexus.com/forums/is-...t=cabin+filter
dasmokedog
dasmokedog's Avatar
I totally agree, and get frustrated when it switches to outside air.
Old 02-07-11, 11:23 PM
chris07is
chris07is's Avatar
Lightbulb online....
^^^ bought online and i can't find it...which website did u purchase this...
Old 02-07-11, 11:26 PM
Jetfire
Royale with cheese
Jetfire's Avatar
when it's raining and cold, you can't have the windows open all the way to quickly defog. so you have to use fresh air to defog the windows.
the humidity from your breath/body with the windows up fogs up the windows too. fresh air clears that up the fastest.
Quick Reply: Cabin filter change
