LED 9006 Bulbs
Old 01-04-11, 06:01 PM
taejin09
taejin09's Avatar
Default LED 9006 Bulbs
http://cgi.ebay.com/ebaymotors/2-x-6...ht_7365wt_1165
Would that work in 2006 IS250 fog light? I am scared of fuse blowing or brightness problems.
Old 01-04-11, 06:09 PM
llamaboiz
llamaboiz's Avatar
yes it will work, of course you'll only use those to roll in at a car show~ those are NOT FOR DRIVING as they produce no usable light.
Old 01-04-11, 06:10 PM
Snubbles
Snubbles's Avatar
why do you want to use LED for fogs?
Old 01-04-11, 06:35 PM
papaalex
papaalex's Avatar
Use HID its brighter
Old 01-04-11, 07:46 PM
Rudebwoy30
Rudebwoy30's Avatar
[QUOTE=llamaboiz;6039382]yes it will work, of course you'll only use those to roll in at a car show~ those are NOT FOR DRIVING as they produce no usable
But Arnt the fogs correlated with your low beams. So once you turn on lights those fogs will turn on as well. Is there a way to jus have fogs on only?
Old 01-04-11, 08:08 PM
RastaRacer
RastaRacer's Avatar
i wouldnt do it, i had led drl's in my acura tsx and they look good but the light output is weak, you may even get a error light on your dash bcuz the output is so low, just go with hid fogs, you can get a good set for under $75 bux.
Old 01-04-11, 08:11 PM
llamaboiz
llamaboiz's Avatar
yes they will turn on BUT~ LED fogs are for 'show' only.
yes, a diy is somewhere on this forum.
Old 01-05-11, 09:03 PM
chi123
chi123's Avatar
Here's the DIY for the fog lights: https://www.clublexus.com/forums/is-...ification.html
And don't do LED fog lights. It's better to just get an HID Kit from DDMTuning or HIDeXtra for about $40. Choose the 6000k color so it's the same as having LEDs but you'll get like 3 times more light than with LEDs.
Old 01-05-11, 11:18 PM
Rudebwoy30
Rudebwoy30's Avatar
can i jus get a yellow bulb and still have the fogs on alone or do i need to get hid kit?
Old 01-06-11, 03:37 AM
Jmags
Jmags's Avatar
link to kit? I have one in my cart but want to make sure it's right, 2007 IS250
Old 01-06-11, 08:34 PM
chi123
chi123's Avatar
http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
Choose the 9006 type for fog lights. If you want to match any LEDs you may have then choose 6000k. And I don't think any harnesses or wiring is needed other than what comes with the kit.
Old 01-06-11, 08:36 PM
chi123
chi123's Avatar
You can just get a yellow halogen bulb for about $14/pair. But if you want the fog lights to run without your low beams on, you'll have to do the DIY.
Old 01-17-11, 12:35 PM
Jmags
Jmags's Avatar
got any pics of it installed?
jbny
CT 200h Model (2011-2017)
29
11-01-18 11:10 PM
Luxurious
SC- 1st Gen (1992-2000)
13
06-26-18 04:28 PM
bfg23
Lighting
07-08-15 07:59 AM
vacarman02
ES - 6th Gen (2013-2018)
30
03-15-15 09:57 AM
Quick Reply: LED 9006 Bulbs
