AirBag light ON *with resolution**TSB*
Old 03-16-12, 03:30 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Originally Posted by Legend217
What ? so the light suppose to turn off ? Mine turned on all the time and I thought it was normal.
When lights come on while driving it usually means there is a problem. Not that the item is functioning.
Old 03-16-12, 05:31 AM
TUNG
TUNG's Avatar
So the airbag "ON" should be off after awhile? You guys are talking about the airbag sign thats on the dash correct? where i place the cd in and what not?
Mines is always "ON" is that a problem? because I thought it was normal because having airbag on is safe.?
Old 03-16-12, 01:04 PM
nosurprise
nosurprise's Avatar
The passenger airbag should not always stay on (indicator is above the CD and says passenger -- check the manual). It should come on when someone is sitting in the passenger seat, otherwise it should be off.
Old 03-16-12, 02:10 PM
TimboIS
Liquid Bra Champion
TimboIS's Avatar
Originally Posted by anthrax144
Nope. Only recalls are covered outside of the warranty period. Sometimes dealers will do it out of courtesy or goodwill but that is usually not the case.
You couldn't be more wrong! If it's a safety TSB it will be covered. Mine was, and not as a "courtesy".
Old 03-16-12, 03:00 PM
laobo979
laobo979's Avatar
To clarify what to look for It should be the SRS light that on the dash.
Old 03-16-12, 03:07 PM
HKS350
HKS350's Avatar
If you guys see this and care about having a working airbag system, get it fixed... When that light pops up the system is disabled.
Old 03-16-12, 07:42 PM
anthrax144
anthrax144's Avatar
It specifically states in the service bulletin:
"This repair is covered under the Lexus Restraint System Warranty. This warranty is in effect for 72 months or 70,000 miles, whichever occurs first, from the vehicle's in-service date."
Sorry, but if you're outside that warranty, it will NOT be covered. The only way to cover it outside the warranty is out of goodwill or out of your own pocket.
Old 03-18-12, 07:23 PM
lancematic
lancematic's Avatar
FYI, if you have electrical knowledge and experience this can be fixed for less than $10. The failure of the wiring harness is at the plug of the airbag, or at lease is was in my case.
Old 03-18-12, 09:05 PM
shiny250
shiny250's Avatar
Originally Posted by ISBU
Are you talking about when you just start the car? The lights stays on for a few seconds and turn off, that's normal and if it doesn't then there's a problem.
I'm talking about the red SRS light that normally comes on during start up and goes away...except mine doesnt go away sometimes.
Old 03-18-12, 10:08 PM
ISBU
ISBU's Avatar
Get it check even though it's not on. The code is still in the history.
Old 03-18-12, 10:14 PM
laobo979
laobo979's Avatar
Shiny250 call your dealer it the issue member are having. My came on a stayed on. Dealer kept my car for two days. They said to get it that the dash had to come off. Either way it's been fixed and I was passed my factory warranty.
Old 04-04-12, 07:02 AM
Sconnie
Sconnie's Avatar
How much is the harness? Is it at Sewell Lexus?
Old 04-04-12, 09:02 AM
Sconnie
Sconnie's Avatar
Were you outside of warranty? did you mention the TSB or just go in?
Old 04-04-12, 08:19 PM
tnis250
tnis250's Avatar
I have this issue for the third time now and will be taking my (out of warranty) car in for diagnosis tomorrow. I documented this problem twice in my extended warranty term and my SA has been informed of the TSB. I feel this should have been addressed with having purchased the extended warranty. Reasonably, I would expect Lexus to cover the part and a good portion of the labor. The dealership has previously advised me that they could get the part comped, however, they likely would not be able to pay for labor... guess I will see how tomorrow goes and update from there.
Old 04-04-12, 08:57 PM
shiny250
shiny250's Avatar
Hey guys. I took the car in last week for the TSIB and found that the code matched that of the one given by the car. They completed the service, and now there is no more airbag light.
Quick Reply: AirBag light ON *with resolution**TSB*
