Ipod integration USA spec static
Old 11-27-10, 08:29 PM
panda327
panda327's Avatar
Default Ipod integration USA spec static
hello so i bought a USA spec ipod integration adapter for my IS250 ...
problem is that when i change songs or turn up the volume .. or when the iphone is not playing songs .. i will hear a static noise
does anyone know how to fix this ?
i have the PA20-Toy from USA SPEC
thank you all in advance
Old 11-28-10, 02:34 AM
JMcDonald
JMcDonald's Avatar
I think there is a TSIB for the aux port plug.....people experiencing the same problems I believe. Do a search and see if you can't find out some more info...ill see what I can find out for you.
Old 11-28-10, 02:02 PM
JDKane527
JDKane527's Avatar
Should contact the manufacturer of the iPod integration kit about it. It's an issue on the module most likely.
The OP is not using the aux port from what I understand. The integration kit is probably just analog and not getting the audio through a digital means, hence the static.
If they aren't able to solve the issue, you could look at other integration kits sold by vendors here like DICE Electronics and VAISTech.
Old 11-28-10, 02:50 PM
brociouz
Uber 1337 Moderator
brociouz's Avatar
Not familiar with this particular product, but does it require grounding or anything?
Old 11-28-10, 03:51 PM
panda327
panda327's Avatar
yea my unit doesnt connect thru aux its goes right to the back of the stock stereo..
i have contacted USA SPEC about this before but they said i would have to send them the unit and if there anything needs to be replaced i would need to pay for it. and the price is almost the same as a new unit ...
i only found grounding for the aux but not for my ipod cable
Old 11-28-10, 04:51 PM
brociouz
Uber 1337 Moderator
brociouz's Avatar
^ Wow, glad I didn't buy anything from USA SPEC, sounds like they have horrible customer service.
Hope you figure it out. Might be worth looking into the TSIB to see if it could be related.
Old 11-29-10, 09:24 AM
Sffd103
Fire Slayer
Sffd103's Avatar
My USA Spec I Pod integration kit worked fine and when I sold it to another member on CL, it worked fine as well. Good luck!
chileboy
ES - 6th Gen (2013-2018)
25
11-14-13 04:02 PM
ybing
GX - 2nd Gen (2010-2023)
04-06-10 06:34 PM
MJMeucci
Hybrid Technology
02-27-10 06:44 PM
Quick Reply: Ipod integration USA spec static
