DIY to disable DRLs
DIY to disable DRLs
so i called a couple of lexus dealerships and apparently in ontario its illegal for them to diable DRLs
wondering if there is a way to diable them myself? by tapping certain wires perhaps?
Tech Info Resource
No. It has to be done with a Techstream device.
It's in the ecu, u need a scan tool to do it like the ones they have at Lexus, I had trouble getting it done but just talk to managers at different deanships and ask when ur buying something or getting a oil change from them
Tech Info Resource
It's illegal to do this in Canada. No Canadian shop is going to do it.
Best bet would be to try a US dealership, but even then, they'll know yours is a Canadian model and they may not do it for you.
^ Yes you can remove the fuse. There's a fuse box inside the engine compartment under the engine covers on the driver's side. I removed the fuse temporarily when my LED DRLs started flickering one side then eventually becoming dimmer. Then reinstalled it after I get another pair of LED DRLs.
It's the same exact bulb for the DRL's and highbeams. Just take the bulbs out. The low beams act as brights anyway as well. I have the Vled's SMT kit so I lost my high beams and I have NO issues with visibility at night
thanks for all the replies guys!
i live in a half rural area so i do need to use high beams at times.. so unfortunately i won't be able to take out the bulbs and loose the high beam function
and i guess taking out the fuse box will in turn loose the high beam function along with the DRL?
lol a very close friend of mine works at a lexus collision center
but i think he mentioned only the dealership gets the computers
maybe i'll ask the ppl who work at his shop
thanks guys!
thanks guys!
Tech Info Resource
