Will those Wheels Fit an IS250 AWD - Part Uno
2FIDDYJB (08-01-20)
#437
What size wheels are you planning to get? I'm getting the same wheels 20x8.5 offset 38 all around. I have awd. I'll be lowered on h&r springs.
#439
I have a 2012 is350 awd that's all stock right now
I have a set of wheels from my other car that are
Wheel Diameter (Inches) - 18"
Wheel Width (Inches) - 8.5"
PCD Bolt Pattern - 5x114.3
Offset - +44mm
Hub Bore - 73mm
It has nice 245/40/18 tires on them right now.
I was thinking about doing some lowering springs down the road but I was wondering if these would work with out rubbing and if I would need some hub rings or different lug nuts like a tuner style.
thanks for the help
Kevin
Offset - +44mm
Hub Bore - 73mm
thanks for the help
Kevin
#440
#442
Offset - +44mm
Hub Bore - 73mm
thanks for the help
Kevin
Offset - +44mm
Hub Bore - 73mm
thanks for the help
Kevin
thanks
#444
I have been over this thread many times over the last few weeks and settled on getting this set up...
19 x 8.5 front with 235/36/19
19 x 9.5 rear with 275/30/19
Of course the place I'm purchasing from is not recommending this since my car is awd. The only thing I wasn't sure about was the offsets. I can only get these in +30 and + 40 so I went with 30 front and 40 rear. Should I change it?
#445
I'm lowered on h&r springs and I'm going to purchase Vossen CVT's 20x8.5 offset 38.
My question is will I rub with 245/30/20?
That's what the shop recommended because they said 225/30/20 tires will not hold the weight of the car. I hope a member can answer my question, thanks.
#446
#447
#449
Help appreciated
I have an 08 IS250 AWD I have some Niche Verona white/machine polished 19 by 8.5's all the way around.
Here is my car as it sits right now. It's horrible. I need to do everything to it, i know.
NOW...Will the following setup work? And should i mess with offset, or let the guys from element wheels choose the most efficient settings for my new wheel's tires...which will be...
http://www.elementwheels.com/proddet...c519105blkmach
I want to use Hankook Ventus V12 EVO II K120's all the way around. And i want the most tire i can get without rubbing AT ALL. Should I go with;
F-225/35/19 R-265/35/19
OR
F-225/30/19 R-265/30/19
OR a wiser setup?
ALSO the rear wheel's are 10.5 inches wide....will this fit? All the calculators say it WILL, just making sure? And should i let them select the offset or is there a recommended, tad bit safer offset or tires i should get?
Please help. Sorry for the long *** post.
OR
OR a wiser setup?
Last edited by Rightarm; 05-24-15 at 01:12 PM. Reason: I didn't know my pictures would be ginormous. Sorry
