Will those Wheels Fit an IS250 AWD - Part Uno
Old 07-27-14, 05:46 AM
  #391
JdSwiper
JdSwiper's Avatar
Can someone please tell me if this setup would work on a 2009 Awd not yet lowered ??
The wheels need new tires so I will change them out but it's the offsets I'm concerned about?
Wheel Specs:
VS-86-0N05 20X10.5 5-114 +45 VVS-086 MSCL
VS-86-0N01 20X9 5-114.3 +38 VVS-086 MSCL
Current Tire Specs:
FK-28-195-012 285/25ZR20 93Y RF FK-452 2 338.00
FK-28-195-008 245/30ZR20 90Y RF FK-452 2 175.00
Old 07-29-14, 07:31 PM
  #392
lexi90
lexi90's Avatar
Wheel Specs:
Current Tire Specs:
The offset sounds about right. I have an AWD with 20'' x 8.5 all around, offset is +38. Regarding the rear tires, you don't want to go with that. You may want to check 275/30-20 as they're cheaper and won't rub. Hope that helps
Old 08-18-14, 10:16 AM
  #393
jonathanz
jonathanz's Avatar
I just bought a 2012 IS250 AWD recently, the car came with stock 17" with 225/45/17. i always like the 370z 19" sport wheels. below are the specs, it's on stock height and I'm not planning to lower, what you guys think? rub? i'll need spacer?
19x9 +47 front,245-40-19
19x10 +30 rear 275-35-19
Bridgestone Potenza
Thanks!
Old 08-22-14, 04:27 PM
  #394
SkyZ33
SkyZ33's Avatar
2010 Lexus IS250 AWD
19x8.5 +35
19x9.5 +40
235/35/19
275/30/19
Lowering on F-sport Lowering Spring
Old 08-22-14, 05:59 PM
  #395
RodJay
RodJay's Avatar
19x8.5 +35
19x9.5 +40
235/35/19
275/30/19
Have anymore pictures ?
Old 09-16-14, 09:21 AM
  #396
BigBawss
BigBawss's Avatar
I just bought my wheels couple weeks ago and just need some pro tips about what tire size should I get and if there's any adjustments on the camber and I pretty sure I'm gonna need some fender modification on this one. currently lowered right now with at least 2 finger front and a lil -finger rear. Pic would be really great too. thanks.
I got a F19x9.5 +22 & R19x11 +25. I was thinking of gettin a 225/35/19 on the front and 255/35/19 on the rear with Continental Extreme DW.
Old 09-16-14, 06:47 PM
  #397
BigBawss
BigBawss's Avatar
Scratch this. Lol I didnt saw that this thread is for awd only. I have a rwd. But it would be really great if some1 can help me on this lol
Old 09-24-14, 08:49 AM
  #398
PearlFocal
PearlFocal's Avatar
Currently I have a 2006 RWD with 18x8.5 +33 front 18x9.5 +38 with 235/40/18 255/40/18. Stock springs.
I really like the 19 inch Linea Corse lc818 and was wondering if I can somehow fit 19inch but with 40 low profile tires for the ride quality. If not then what is the closest alternative? 225/40/19 and 245/40/19?
How is the quality difference between 40s and 35s?
Old 09-29-14, 12:14 PM
  #399
lemans777
lemans777's Avatar
40 profile is huge.on 19 the minimal is 35.if you will go with 40 you will rub not on top.you will rub underfender plastic in front and back of wheel on turns(which are face to head and tail of car)
Old 11-17-14, 06:57 PM
  #400
AhMeTaPoo
AhMeTaPoo's Avatar
Pretty sure I will rub with varrstoen es7 wheels but curious what tire size I should go on them planning on getting 19x9.5 all around but +12 front and +22 rear will be lowered on road magnets for now and maybe bc coils when spring hits..
Old 11-21-14, 12:31 AM
  #401
Morales92
Morales92's Avatar
wow lol, and all this time i thought i couldn't run a staggered setup.
okay well i need help choosing tires. I have 18x9.5 all around with +22 offset. i will be lowering the car on f sport springs or h&r springs.
Old 11-30-14, 09:34 AM
  #402
MarkoJames
MarkoJames's Avatar
hey guys -
i have an o9 is 250 awd, not lowered and on stock wheels/tires . i'm looking to get a winter wheel/tire set-up and ran across these:
Bridgestone Blizzak LM-22 235/50R18
18 Inch Lexus Ls460 Ls600 Wheel Rim Factory Oem; Rim Diameter: 18; Rim Width: 7.5; Offset: +32mm
Number of Bolts: 5; Bolt Pattern: 5x120mm
Would these fit nicely?
Thanks in advance!
Marko
Old 12-26-14, 09:13 AM
  #403
NJLexus13
NJLexus13's Avatar
Need tire sizes that will not rub.... 19x8.5 front 38mm offset
19x9.5 rear 40mm offset
Lowered on f sport springs
LFA gunmetal replica wheels...
Gotta get winter tires lol
Old 01-25-15, 07:49 PM
  #404
BriIs250
BriIs250's Avatar
Default Need help with the right size and tires so my 2011 is250 awd wont rub
Planning on getting some 18 Work Vsxx rims but not sure what size to get. I have some pictures of my stock height. Also going to drop an inch with bc coilovers but again i have awd. I dont want to counter a big issue later. Need help with sizing and tires.
Old 01-26-15, 09:30 AM
  #405
BriIs250
BriIs250's Avatar
Default Wondering what other specs u got running staggered
19x8.5 +35
19x9.5 +40
235/35/19
275/30/19
Hey man wondering if u have had any rubbing issues with ur staggered set up on 19". I would greatly appreciate it. Im looking forward to doing the same size as u. If u can hit me up with more pictures that would be great. I have a 2011 awd and also wondering if ur on anything besides fsport springs. Thanks
Quick Reply: Will those Wheels Fit an IS250 AWD - Part Uno
