Will those Wheels Fit an IS250 AWD - Part Uno
Old 04-03-14, 10:05 PM
  #346
IS250Vic
IS250Vic's Avatar
Hey guys,
Looking into buying a set of non-staggered 19's and needed some help from the CL community. Wheel specs are as follows:
Wheel Size: 19x8.5 +35 (all 4 corners)
Tire Size: 235/35/19 (all 4 corners)
Mine is a 2011 IS250 AWD, currently lowered on BC Coils lowered 1.5 inches (i think? ground to fender = 25.50 - 25.75')
Am I at risk of rubbing in the front? Not sure if it will be a flush fitment or not, and if fender work is required. I am looking to pick these wheels up tomorrow, so please let me know soon!!
Thanks in advance!
Old 04-03-14, 10:50 PM
  #347
IS250TW
IS250TW's Avatar
Originally Posted by IS250Vic
Hey guys,
Thanks in advance!
I ran almost the same spec for a while and yes, the front will rub a bit
no need to roll fenders but the front fender tab would be your main problem
it wont be that flush but its close
Old 04-04-14, 11:39 PM
  #348
IS250Vic
IS250Vic's Avatar
Is it safe to assume I will not rub as much with a 225 in the front?
I've found this article for bumper tab relocation, which is great, however it does not seem to be a permanent solution.
http://www.wrongfitmentcrew.com/foru...ods-quot/page3
^post #46
Picking them up tomorrow, I am hoping it will not just eat through my front tires lol. Here's a few photos of my front end as it currently sits; hoping this will provide a better idea if i need to roll/relocate bumper tabs or not:
Thanks in advance
Old 04-04-14, 11:54 PM
  #349
IS250TW
IS250TW's Avatar
^post #46
Thanks in advance
Yes with 225 you'll probably rub less. But your speedometer wouldn't be as accurate as in 235/35
No need to worry, you'll be fine
When I ran 8.5 +30 with 235/35, its the fender liner that was ate through instead of the tires
I would say if you want to go more aggressive in the future, then go with tab relocation and roll.
But for now, relocating would be a good idea. But if you're planning to put some lowering springs, I'd say you can leave it alone as long as you can bare with the scraping sound between the tires and the tab every dip you hit (that's what I did at that time.... )
Old 04-05-14, 12:22 AM
  #350
IS250Vic
IS250Vic's Avatar
Haha its currently on BC coils, but the roads here in Canada are.... brutal..... I want to lower it more, but with so many potholes on our roads its just easier to raise it up a bit
As long as my current height will not require bumper tab relocation after installing 19's, I'll be satisfied
Old 04-08-14, 02:12 PM
  #351
SeanO
SeanO's Avatar
I wanna run this exact same setup pretty well.. Except my 08 is250 will be on fsport springs and shocks by the end of this week, I'm running a 255 series tire right now to stay closer to spec but I'm gonna be switching to the 235 series i think..
With the 235/35/19's on 19 by 8.5's (lowered on f sport springs and shocks) do i need to worry about rubbing at all?!
Old 04-08-14, 02:30 PM
  #352
massaker
massaker's Avatar
I cant see it rubbing at all except maybe in the front rear liner u might have to heat it up and push it in. You didn't say any crazy aggressive offsets so i think it sounds like you will be ok.
Old 04-08-14, 08:17 PM
  #353
ChiLexus10
ChiLexus10's Avatar
Originally Posted by ChiLexus10
Let's try this again
Xxr 527
18x 8.75 20mm front or 35mm
18x 8.75 20mm rear or 35mm
Or same front size backs 18x9.75 20mm
Looking for a flush setup. Megan coil overs stock is250 brakes
Car is 2010 is250 awd and rolling diameter had to be close to same
Also tire thickness will be 35/40 as the roads in Chicago are extremely bad.
Bump...I got the wheels.20mm offset all around.18x8.75 front 9.75 rear.what tire size for a little stretch
Old 04-09-14, 10:50 AM
  #354
Nixcision
Nixcision's Avatar
Default PLEASE HELP: 18x8.5 35mm offset is250 awd
I am about to buy some rims for my is250 awd.
Will these fit?
18 x 8.5 35mm offset with 225/40/18 tires
(all around)
If i lower on f-sport springs, will they still fit?
Thanks!
Old 04-11-14, 04:49 PM
  #355
DaXxJaPxX
DaXxJaPxX's Avatar
getting some 20x8.5 +35 wheels and i'm lowered on H&R springs, what tires would you suggest
235/30/20, 235/35/20, or 245/30/20?
thanks!
Old 04-11-14, 06:03 PM
  #356
Nixcision
Nixcision's Avatar
thanks!
I would go with the 30's to avoid fender mods... Its still gonna be close because I assume you've got a decent drop with h&r's. But im not sure.. Your rims may already be too big.
Old 04-11-14, 06:35 PM
  #357
dangerofs
dangerofs's Avatar
anyone out there running 19X10.5, what tire size u guys running?
Old 04-11-14, 07:06 PM
  #358
DaXxJaPxX
DaXxJaPxX's Avatar
Yea I'm thinking the same as far as the sidewall goes. Someone on page 23 said they run a 20x8.5 with a 245/30/20 on roadmagnets with no issue. If thats true, I should be fine I'd think
Old 04-16-14, 10:59 AM
  #359
MrKhristop
MrKhristop's Avatar
Default After market wheels question
Just brought my is 250 awd n I was thinking of putting on 20" rims, can I run on 20/9's all around instead of staggered? Or do I have to go staggered..
Old 04-16-14, 11:10 AM
  #360
sm1ke
sm1ke's Avatar
There is less stress on the AWD system if you don't stagger the wheels. That said, if you want to get the same look (in terms of fitment) from front to rear, you will likely have to run staggered sizes. I believe this is because the rear fender arches are slightly wider than the front fender arches.
Quick Reply: Will those Wheels Fit an IS250 AWD - Part Uno
